Question about Philips 23PF9966 23 in. HD-Ready LCD Television
Philips 23PF9946 2 inch vertical line just left of centre as you face the TV, it changes colours to match what is happening on the screen before finally becoming a grey/black colour. The line takes up all of the screen and appears after a period of time 15min to 1hr and is on the screen no matter what is being watched. If I turn off the tv and then come back 15 to 30 mins later it is still there, if left longer it goes away onl;y to come back again after viewing for the time period stated.
5 Suggested Answers
jdbouncer
  • 72 Answers
SOURCE: philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Posted on Apr 29, 2008
freetek
  • 5568 Answers
SOURCE: flickering in half screen after 1 to 2 hours
Probably caused by a power supply nearing its death.
Try to verify this by placing a portable fan to the side of the set with airflow directed at the vented sides.
If this lengthens the operating time, there is a good chance that some minor components in the main supply have developed low values of capacitance and higher losses which worsen with warmth.
Listen closely at the vents with the sound turned down to attempt to detect a squealing sound while the TV is in its failure mode; if you find this, it is also a sign of power supply trying to die.
A tech equipped with a capacitance meter that measures losses at the same time, could find and replace the weakened parts without a whole lot of labor and little cost for parts.
Posted on Nov 26, 2009
SOURCE: while watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Posted on Apr 13, 2010
  • 9 Answers
SOURCE: my philips flat screen tv
It is possible that you may need to download an upgrade to a flash drive and then with the tv off, insert the flash drive into the usb port on the tv. Turn the tv on and it will load itself. Check Philips website for updates...
Posted on Sep 10, 2010
Philips 32 inch LCD has colored vertical lines when powered on.
this sounds like a screen fault to me
try grabbing both sides of the tv and giving it a twist
this will either give you more lines or make ur lines go away if this happens u need a new screen
May 15, 2012 | Philips 32PFL3505D 32 in LCD TV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
I have a panasonic 48 inch plasma TV which has developed a fault. There is a yellow line down the centre of the screen on all channels. Is the TV knackered?
Hope this will help in solving the problem.....
Jun 15, 2011 | Televison & Video
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Th-50px70b
when doe s this happen on hd tv bad signal on antenna will cus ethat to happen heavey comprsed dvd bunred will also do it may need better antenna ok
Oct 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Philips 23PF9966 23 in. HD-Ready LCD Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
