Question about LG Heating & Cooling
Microwave does not heat. Power lights and display lights are working properly but it is not heating anything
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 07, 2010
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Not heating
If the oven is doing everything else properly (light comes on, fan runs, turntable goes around) but there's no heat, you may have a failed magnetron tube (the microwave source). There's also a relay that controls power to the tube that may not be working correctly, or the control circuit board is bad. It's also possible one of the door switches is not working (so the oven thinks the door isn't closed), although this usually keeps the turntable and fan from running.
Microwave oven service is not for do-it-yourselfers. There are potentially deadly voltages present even with power off, and a chance of microwave leakage if repairs aren't done properly. Let a professional give an estimate to repair it, or just replace it if it's under $100. (When I was servicing these things it wasn't unusual for a repair to cost over half the price of a new one. That's one of the reasons so few shops still work on small appliances.)
Jan 31, 2010 | LG MV-1444Y Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Doesn't heat anything
HI, there is only one in-line fuse link that is designated for the power board. this is concerning the Magnetron. this heating device has failed. replacing the Magnetron will fix this issue.
Jun 17, 2009 | Emerson Black Microwave Oven
My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 25, 2009 | Whirlpool MH2155XP Microwave Oven
Microwave doesn't heat anything
Benjamin
Apr 19, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating up anything
Not knowing how much run time you have on the microwave , makes it hard to diagnose the problem but If everything appears to be working properly (as you describe) then you may have a bad/damaged or disconnected magnetron tube inside it. That kind of service should be done by professionals. Exposure to Microwave energy is not something you should mess around with unless you know what you are doing.. Good Luck
Aug 13, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave won't heat anything
take the cover off the machine and look for a 13amp fuse that supplys the tranformers. BEWARE!!!
when you open the machine disconnect from the mains and do not touch the high power circuits the capacitors can hold a charge that can kill.
Jul 06, 2008 | GE JES1142SF Microwave Oven
Heating & Cooling Logo
35 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
