Question about Sharp AL-1651CS All-In-One Laser Printer
Reset drum - Sharp AL-1651CS All-In-One Laser Printer
  • 567 Answers
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Posted on Sep 06, 2010
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Replace drum, still says replace the drum and now it won't print.
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
May 12, 2010 | Brother MFC-9440CN Laser Printer
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Okipage 8w print drum
Reset the Drum Count:
Open the Status Monitor.
Click Printer Setup tab.
Click on Printer Menu button
Click the Maintenance tab
Click on the Drum Counter Reset button.
May 15, 2009 | OKIPAGE 6w Led Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Sharp AL-1651CS All-In-One Laser Printer Logo
307 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
