Question about IBM ThinkPad A22m 2628 Notebook
I got the laptop and told it only had a dead battery. After I charged the battery about 5 hours and then turned it on 4 of the 5 lights at the top of the keyboard come on green, about 2-3 seconds 3 lights go off leaving only one green light (the last light on the right stays green). Nothing ever apprears on the screen. What does this mean?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
Nurvo tablet will not turn on or off
Have you charged the battery? Please charge it at least for 2 hours, and then try this:
1. Unplug the AC adapter,
2. Remove the battery,
3. Press the power button and hold it for 15 seconds,
4. Install the battery,
5. Plug in the ac adapter,
6. Turn on the laptop.
If it does not work, then probably the motherboard is dead.
Mar 04, 2014 | MSI Computers & Internet
I cant charge my sensei smp 2gbs from my laptop.even if i plug iton my laptop for 4-5 hours it switches off after 2-3 minits
This is not a problem with your laptop or PC (so you have posted in the wrong category), but, it would seem that the battery in your mp3 player is dead and would need to be replaced. I assume that you tried to use different cables to charge it.
Jun 17, 2012 | Computers & Internet
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Nov 01, 2010 | SYMA Toys industrial Syma S032 Ready to...
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Battery won't hold charge - fine for 4 hours or so then dead
need to check battery and charging system with tester sounds like possibility of a bad charging system, alt or voltage regulater or bad connections
Feb 18, 2009 | 1992 BMW 5 Series
Charging lap top battery
As soon as the AC is plugged in, the battery will start to charge. The battery light located somewhere on the laptop should indicate you that it is charging. It does not matter if the laptop is turned on or off.
What you explain here about the first battery is very common for a 4-5 y.o. laptop. The longevity of the battery mainly depends on the number of charging/discharging cycles it encountered. If the second battery you want to try spent more time in a carrying case than in the laptop, it may still be usable. But do not expect to go over 1 hour of autonomy with it.
May 28, 2008 | Computers & Internet
IBM ThinkPad A22m 2628 Notebook Logo
41 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
