Question about Whirlpool Washing Machines
The machine is not filling with water than it shows F09 and then FA on screen. Its a 6th sense and about 4 years old
    President:
  • 1,932 Answers
Error F09 means Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Thank You
Posted on Sep 06, 2010
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine
All washing machines have a water level sensor, this can be a tube into the drum that leads up to a switch normally attached to the inside higher up, what happens is the tube gets clogged up with muck and gives a false reading, which needs cleaning out.
Another problem may be your input valve normally a sngle cold water input, the valve can get clogged with limescale and its just slow to switch off even when the power is off. The default is a closed position.
Try switching the machine off at the plug as soon as it finishes, if it starts filling up its the input valve, these can be under twenty pounds on popular auction websites.
May 11, 2014 | Whirlpool Washing Machines
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine- door light keeps flashing & it will not start the cycle,have to turn off the machine for the door to open .the machine is 4yrs old nxt month.
Hi could be 2 things
Motor brushes worn but at 4 years old unlikely
Or as mine turned out to be dry joints on the controller board just fixed it tonight I also replaaced the brushes on the motor as my machine is 6 years old and were worn
Both jobs are easy thanks hope this helps
Jan 31, 2011 | Whirlpool AWM6100 Front Load Washer
Cosa significa il codice errore F12-F09 in una lavatrice whirpool modello AWM8103/2
la lavatrice mi si blocca con un codice F09 e poi dopo una diagnostica finisce in FA. Posso fare qualcosa per sbloccarla... si è rotto l'acquastop? Grazie
Jan 11, 2011 | Washing Machines
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
My Whirlpool 6th sense washer displayed f09 so I left it. next day it seemed OK but does part of the wash and comes up with FA
Thank you for your response. I finally managed to contact someone at Whirlpool who advised that the error code FA indicates a component problem and may require a replacement part. Unfortunately a serviceman is required.
Jan 29, 2010 | Whirlpool Washing Machines
Hi i have a maytag front loading washing machine its about 4 years old haven't been able to find a model number either on the back or inside the door i get an number 5 error. the machine starts it filling...
I believe you are describing a tS code.
If it is tS showing it is an indication that the termistor is shorted. The thermistor is the temperature sensing device used on this dryer.
Before replacing the themistor check for a clogged lint screen or dirty vent pipe.
If these are clear and you are still getting the code the thermistor would need replaced, the resistance of the thermistor should be about 10K ohms at room temperature.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
May 22, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
378 people viewed this question
Dan Webster
Dan Webster
Sal De
