Question about LG FLATRON L1950B-SF 19" LCD Monitor
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from the monitor, which does not sound natural to me. Is it worth trying to repair the monitor or buy a new one?
  • g3g4tso Dec 09, 2010
    Thanks mate! I'll try it out once I get a chance.
  • 3 Answers
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Posted on Dec 09, 2010
Testimonial: "Thanks mate! I'll try that once I have some time. "
    New Friend:
You may need to replace the diode P6KE10A. Test if it is shorted.. Otherwise fault will persist
Posted on Apr 01, 2013
  • Umesh Radia Apr 01, 2013
    you may need to replace the diode P6KE10A. Test if it is shorted.. Otherwise fault will persist
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
it was a blown or bulging electrolytic capacitor at the PSU with high ESR. just replace bad caps to a low ESR a panasonic brand much better 105c rating.make sure the same voltage and capacitance rating to avoid other possible problem may occur good luck.
Jun 23, 2012 | LG Flatron Computers & Internet
I just bought an LG Flatron LCD 295LM Monitor/TV today and was told that it works and just needed a power adapter. The monitor's power ratings are 15V 5A but I am using an IBM power adapter with 16V...
I have a feeling that the monitor has the problem, monitor can take +/- 10% voltage variation.
You said the backligts are on, do they stay on? You should be able to see the glowing screen in the dark room, if it does stay on, then you may have T-CON board problem.
I cannot see how the seller says that it works when the person does not have the power supply to try it out first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 23, 2011 | LG Flatron 295LM 22" LCD Monitor
LG flatron T13SH no display with power LED fast blinking.
no video signal - video card broke down or screen resolution is to high
try boot in safe mode and un install de video card
Feb 20, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
My LG 17" CRT monitor , screen is blinking rapidly with slightly dark shadow. pl. help
If it is an older monitor, this may just be a sign of aging. It is possible that the adjustment knobs and buttons on the front, bottom, or side of the monitor may have been moved. Try adjusting those to see if you can tone out the problem. Also check to make sure the monitor cable is secure to both the monitor and the computer. You may also try plugging the monitor's power cable into a different outlet. Finally, you could try adjusting your video properties in Windows, but that's probably not the problem unless you have been in there before.
Jul 20, 2010 | LG Flatron F700P 17" CRT Monitor
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Green Power LED is lit- But no image on the screen
Hi, I have just repaired one of these with the same problem. Turned out to be a 680uf 25v capacitor that had failed. Capacitor was visibly domed. Easy repair with new capacitor. Hope this helps.
Aug 10, 2008 | LG Flatron L1715S 17" LCD Monitor
LG FLATRON  L1950B-SF 19" LCD Monitor Logo
841 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
