Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Whinning noise after 1 to 2 min, but not on drainning
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 07, 2010
Cause of whinning noise when trying to start xg350 motor does not turn over. Not a clicking sound but a high pitched whinning sound.
1) Most likely.
Your starter is an electric motor, with a gear on one end.
Mounted on that same end is a part called a "Bendix" or an "overrunning clutch".
When that just mentioned part fails, the starter will not engage the flywheel, and you will get the noise of which you spoke.
2) Less likely.
If your timing belt fails, he engine will turn over at a high rate of speed, but it will not start.
God bless your efforts.
Jan 19, 2018 | Cars & Trucks
How to fix whinning noise when car is accelerating, or turning? Is the whinning noise an electrical issue, fuel pump, power related, etc.?
the whining noise is your engines alternator bearings
they are worn out , the alternator is close to failure
it is barely producing any voltage
( the battery light in the dash only indicates that the alternator is no longer generating any amperage )
Apr 22, 2015 | 2001 Buick Regal
WHY DISHWASHER MAKES A WHINNING NOISE
If the dishwasher is making a loud whining noise, the drain pump or motor bearings are defective, the drain impeller or wash impeller might have worn out. All these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Jul 14, 2014 | LG LDF6810ST Stainless Steel Built-in...
Whinning noise when acceration. Engine accelarates fine but there is also a whinning noise
check alt bearing,open hood & listen while running,turn off engine and remove drive belt then start engine to see if noise goes away.
Jul 10, 2014 | 2008 Jeep Compass
98 olds intrigue fuel pump making loud whinning noise but running great.
Ok 1 did you buy a brand new pump. 2 did it come with a replacement wiring harness. 3 if either 1 of those answers are no go buy a brand new pump with harness. If yes to both you got a bad pump.
Jan 12, 2018 | Oldsmobile Intrigue Cars & Trucks
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Loud noise!
May be a bad bearing on belt tensioner or idler pully
Feb 13, 2010 | 2000 Jeep Grand Cherokee
2002 dodge durango whinning noise will your
Thank you for getting back to me. I would like you to check your transmission fluid. start the engine and let it warm up at idle speed for about 15 min and check the fluid. It sounds like you do not have enough in it, there for the whining noise with increase of speed since your transmission is speeding up with the rate of your vehicle. If this does not help and the problem persist please let me know. If the noise you were hearing was coming from the u joints of the vehicle it would not make a whining noise with increase of speed. The u joints will only make a noise when they are going bad when the vehicle is shifted into any gear from the shifter( EX: park to drive, park to reverse ECT.)
Jan 09, 2010 | 2002 Dodge Durango
1997 960 volvo.think? auto tranny pump makes whinny noise cold.
Your transmission is going to fail sooner or later, the whining noise you hear is the the clutch packs in the transmission going out.
Mar 26, 2009 | 1996 Volvo 960
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
111 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
