Question about Alpine Air XL-15 Air Purifier
No lights no fan on Alpine Air XL-15
Used unit arrived in mail. Plugged it in and turned it on. lights on front of unit came on briefly. Fan did not move. Safety interlock button is pushed down as far as I can tell. Not sure what the electronic unit that has a round plastic tip sticking through the rear screen does.
Can't tell visually if the fuse is blow. Appears to be clear glass. What to do?
Thanks for any help
  • 1 more comment
  • JimmR Jun 23, 2008
    For this unit I determined that the power connections the motor had been corroded away. Ozone is very corrosive. I replaced those connection tabs and the unit started back up.
    There is a trouble shooting guide on the company website that was very useful.
    Thanks for the info. Fuse was clearly blown after checking it against an unblown fuse...could tell visually once I saw an unblown fuse. Continuity checker would have confirmed that more quickly. The fuses can be found at home depot or radio shack. The website for manufacturer parts was selling a fuse for 20bucks.....whereas I got them for about 2 bucks each at home depot.
    I bought some connection tabs (pressure fittings...squeeze them shut with a pair of plyers) from an autoparts store replaced the corroded tabs that supplied power to the motor, hooked everything back up and everything worked.
  • tjstick Jul 29, 2008
    received alpine xi-15 in mail,plugged it in same as jimmR no lights no fan fuse looks,I can see the small wire inside the glass tube c.tom
  • 981 Answers
Use a DVM continuity function to see if the fuse is blown, and check all the DO FIRST literature packed with the thing. You probably get to take a note out of the ionizer chamber.
Posted on Jun 23, 2008
Why would new fan motor blow the air backwards
WIRES ARE CROSSED OR REVERSED, OR PLUGGED IN WRONG. SWITCH THEM, SEE IF THAT WORKS, DO U UNDERSTAND ?
Apr 29, 2014 | Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
I put in a new Living Air XL-15 fan but no go.
Make sure that the pin on the back cover penetrates deeply enough into the unit to activate the power. I too couldn\'t figure out why mine wouldn\'t start until I pressed hard on the bottom right corner of the back cover. When I did the unit started immediately because the pin wasn\'t fully inserted. To solve the problem I held the cover tight with a piece of duct tape and haven\'t had a problem since.
Dec 13, 2013 | Alpine Air XL-15 Air Purifier
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
I cleaned my alpine air XL-15 and it will not go on.
Yes, the plates contact the screen. If you used soap on the plates there may be a residue. Use nonsudsing ammonia OUTDOORS and a toothbrush, then rinse thoroughly and let it dry before putting it back. It may take a few minutes of running to get the ozone going again after that. The interlock switch on some units is pushed back to go on, on others pushed down. Make sure the little plastic doodad (or metal on older units) is pushing the switch properly - you'll know if the fan doesn't go on.
- Robert
www.rawfoodlife.com
Feb 03, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
185 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
