My battery cheges when win XP is shut down or hibernating. But after power up, the battery does not charge, monitor keeps flickering and swithcing between "low power" brightness and "normal" brightness.
  • 2,567 Answers
Try removing the battery from the laptop & see if it will power up. If not, then you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 07, 2010
I have a Thinkpad t60. For the past few days it won't go into hiberation when I close the lid. It just stays on and consumes the battery.
I have seen this issue before with my T60. It seemed to be related to not having restarted my laptop in a while. I used to use hibernate rather than shutting down my laptop for weeks at a time. Actually restarting my laptop seemed to get hibernate to work again.
In addition, you can check to see if for some reason the hibernate option has been disabled.
In Win XP (Win 7 is very similar):
  1. Click Start and select Control Panel.
  2. Double-click Power Options.
  3. On the Hibernate Tab, ensure Enable hibernation is selected (check mark).
  4. On the Advanced Tab, ensure that the setting for When I close the Lid is set to Hibernate (select it from the drop-down list if necessary). There should be an option for when plugged in and when on battery. Set both to your preference.
Hope this helps. Thanks for using FixYa.com
Jan 18, 2010 | Lenovo Thinkpad T60 Notebook
Computer asleep
If you go to control panel > display settings > Screen Saver > Power (win XP) or Control Panel > Power Settings (Vista).
This will allow you to turn off the sleep or change the amount of time until the computer goes to sleep or turns the monitor off.
Mar 26, 2009 | HP w1907 LCD Monitor
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Nov 15, 2008 | Computers & Internet
Power jack repaired now comp shuts down
the power jack plug is still loose. Tad risky opening up the shell like that, perhaps the problem was deeper than just the jack....I am curious if it can do a full battery charge if you left it recharge for a couple of hours.
Jan 03, 2008 | Averatec 3200 Notebook
No display
Check your power cord/PSU and all connections between the laptop and the wall!
This may also be a sleep/hibernate problem, from ACPI control. The "other" blinking LED makes me suspect that as the MOST likely cause!
1 To test this theory, press any key hat looks like "sleep" or "suspend". Wait 20 seconds to see if laptop wakes up.
2 if not, then press the power button and HOLD IT DOWN continuously for 10 seconds. If the blinking light goes off, we have discovered the problem! If so, continue with step 3.
3 Now, the computer will be "off" entirely, and we can do a "cold start". Press power button again, and wait for start up as usual. Note if the HD light has come on now, (and flashes to indicate the boot process is working, if not, stop and let me know this -or replace HD with a new/known good one to proceed)
4. When/if the laptop reaches normal desktop, check the battery level FIRST. If it is NOT full (assuming the plug has been in all this time, battery SHOULD be charged) your battery may be damaged. Go to step 5. Otherwise, if battery is good, go to step 6.
5 Turn the laptop off normally, and let let it charge for a a few hours, to determine this. Start and check levels. If it is not showing greater charge level (and does not fully charge after some more time) then the battery may be bad. Check voltage with VTVM, or if you do not know what that is, take battery to a repair shop and ask them to do it. Voltage should match or exceed the levels stated on battery labels.
6. Regardless of the cause, be aware of this fact: The greatest friend a battery has is ACPI/Power Saving "sleep/suspend/hibernate and related HD spin down settings). But it can ALSO be a battery's greatest enemy in this situation:
NEVER disconnect the power cord for more than a few seconds when you laptop is suspended/sleeping or hibernating! In fact, it is best to relocate the laptop when it is awake, to be sure removing the power is registered in BIOS. Why? While the laptop uses less energy in these suspended power states, if the laptop is left without AC power (bad cord, bad transformer/PSU or bad connection in wall socket) for an extended period while it is asleep, the battery has no "shut down" ability, so it depletes the battery PAST its safe depletion levels. If the laptop is "awake" when this level is reached, it shuts down automatically. But the paradox is, most laptops must BE awake to do this!
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
