Question about HP PhotoSmart 7260 InkJet Printer
Hp 7260 will not pick up paper
I have had no issues printing until today. Now, whether I am using a full-sized page or the 4X6 insert, it will not pick up the paper. I hear it try and then it goes to the flashing red light. Any thoughts?
  • 1 more comment
  • Anonymous Aug 22, 2008
    I am having this problem also. I dont know why either. Can any one help?
  • aqritt Nov 28, 2008
    I am having the what sounds like the same problem. My printer will not pick up paper. I have tried more and fewer sheets. Any advice other than buy a new printer?
  • Anonymous Dec 11, 2008
    My printer will not pick up the premium photo gloss paper. Works with other papers. Did it before but will no longer .
Yea, I have the same problem. The only answer I can think of is to never buy another HP printer. I've had nothing but trouble with this piece of garbage!
Posted on Oct 02, 2008
Can I print small photos Using 4x6 photo paper??
you can print more photos per page but it requires you to set up the page and the number of photos on the page
one of your photo shop programs will have that ability and it will take some trial and error to get the right results
basically it will work like this select a photo and insert it on to a page
select another photo and insert it onto the same page next to the first one and so on until you have a page full
the page can be sectioned into squares as well
when you have what you want go to print preview and if that is working then print
after that use a sliding paper cutter to cut the photos from the page
Sep 04, 2016 | HP Envy 4500 e-All-In-One Printer, Copier,...
Paper size detected not correct
What size paper you are using? if you are selected 4*6, you have to use same paper right?, pl clarify
Feb 02, 2012 | HP OfficeJet 7310 All-In-One InkJet...
Couple of issues...
1. Is this an actual HP cartridge? 2. HP Photo Smart Essentials 3.5 software, available for free from HPweb site will let you change how many photos on each page.
May 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
Oct 13, 2009 | HP LaserJet 3200 All-In-One Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Printer size small
Go to printer preferences and settings and put the right setting there.
Also in your document check the margins and print preview
Oct 13, 2008 | Dell 1700n Laser Printer
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP PhotoSmart 7260 InkJet Printer Logo
225 people viewed this question
Seeker5211
Seeker5211
