Question about Wahl Cord/Cordless Custom Shave System 4000 7367 Electric Shaver
How to open a model 4000 to replace the battery
  • Wahl Master
  • 1,610 Answers
Remover the foil and cutter. Under the cutter are two metal clips. Remove clips to separate the front and back halves and access the battery
You will find a replacement battery at shaveroutlet.com
Posted on Sep 06, 2010
Models: KCT, KCP Power Switching device: Standard Open- Transition 30 to 4000 Amps Programmed- Transition 150 to 4000 Amps Electrical Controls: MPAC 1000 Problem: Power went off, generator Started,...
try to find the manual , these units have a pre program set from the factory, dissconect the unit at the generator 1)battery terminal 2)main switch on generator 3) reconnect battery and turn on the switch,press auto,should reset
Jun 09, 2011 | Kohler Electrical Supplies
How do you change the batteries?
Replacing the batteries The thermometer is supplied with two 1.5 V type AA (LR 06). For best performance, we recommend Duracell ® alkaline batteries. Insert new batteries when the battery symbol appears on the display. Open the battery compartment. Remove the batteries and replace with new batteries, making sure the poles are in the right direction. Slide battery door back until it snaps in place. To protect the environment, dispose of empty batteries at appropriate collection sites according to national or local regulations.
Feb 08, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
How to locate the Cmos battery
The CMOS battery is the RTC battery. Real Time Clock.
It's smaller version of the CR2032 batteries you're used to seeing in a desktop computer.
It's in a plastic holder that resembles a bag. The plastic 'bag' wraps around the battery.
There are two wires attached to the battery, and come out of the 'bag'.
One wire connects to the Positive pole of the battery, and the other wire connects to the Negative pole.
The wires are soldered to the Battery.
At the end of the wires opposite of the Battery is a small white connector. It's a Male connector.
The Male connector plugs into a Female connector on the motherboard.
Once you have the RTC battery pack removed, and the battery itself removed out of the 'bag', you can match up a new battery to it. Carefully make a **** in the side of the bag, and remove the battery/wire combo.
Have a competent repair person remove the wires, and connector to the old battery, and solder the wires/connector to the new battery.
Install the battery/wires/connector combo back in the 'bag', use glue to seal the 'bag' once more.
(Or you can use silicone)
The RTC Battery is on the BOTTOM of the motherboard. This means the laptop has to be completely disassembled in order to access the RTC Battery.
In the above heading it states Acer TravelMate 4000 PC Notebook. This is the TravelMate 4000 series.
There are many models in that 4000 series.
The Model Number is on the bottom of the laptop.
Models in the 4000 series are; 4000, 4010, 4020, 4050, 4060, 4070, 4080, 4100, 4150, 4200, 4210, 4220, 4230, 4260, 4280, 4320, 4330, 4330G, 4400, 4500, 4520, 4530, 4600, 4650, 4670, 4720, 4730, and 4730G.
The above Model list may not be complete.
The disassembly guide for the Acer TravelMate 4000 series will cover all of the above models.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Scroll down with your eyes to the Travelmate heading.
Go down to the third line that starts with 2700, read across to 4000.
Click on 4000.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
However if you do not have the latest Adobe Reader, I would suggest downloading it.
(Adobe Reader 9.3.4)
After you click on 4000 nothing will happen for up to 30 seconds. (Maybe more)
The screen will be blank. The file is downloading in the background, and after it has fully downloaded, the first page will pop up.
For additional questions please post in a Comment.
Would appreciate it if you would rate my solution.
Regards,
joecoolvette
Oct 21, 2010 | Acer TravelMate 4000 Notebook
How to change cmos battery Acer notebook model 4002LCi.
Cmos battery usually but not always is held to the mother board with spung steel clip Its like a large watch battery often,that is needed when power down for the clock,time of your pc(and other functions).
Youll have to open you pc up to get to it,youll see it when you do !--Good luck!
Davey Snake!
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
Magellan Maestro 4000 will not hold a charge longer than 30 min
replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Dec 27, 2008 | Magellan Maestro 4000 Handheld GPS...
Vivitar vivicam 4000 replacement battery required.
Here's one I found that works:
http://www.buy.com/prod/kodak-easyshare-rechargeable-camera-battery-lithium-ion-li-ion-photo/q/loc/33409/90130097.html
(Kodak part # 8499741)
Don't recall where I found the info that it works as a replacement, but I've been using it successfully since July 2007. Don't know yet if I'll experience the same "memory" problem I had with the original battery.
Dec 17, 2008 | Vivitar ViviCam 4000 Digital Camera
Wahl Cord/Cordless Custom Shave System 4000 7367 Electric Shaver Logo
817 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
