Question about Baby Gear
88 cavalier 2.8 v6
I started my car. it ran fine for about 2 mins . i turned the headlights on & it died. it quit firing. whats up?
  • jeff chaney
    jeff chaney May 13, 2008
    if anyone can help please do
  • 2,039 Answers
Check the charging system if the alternator dont charge you ran on battery only as soon as you ask extra juise from battery by putting on the light n ot enough juise in battery and the car stall check it out good luck pierre
Posted on May 16, 2008
I have a 92 camaro 3.1L v6 and its not firing. i changed the coil and distributor and it ran for 20 mins then died. any solutions?
Wrong. The 92 Camaro CORRECT firing order is 1-2-3-4-5-6. Straight from Chilton's and the gm service manual.
Oct 23, 2012 | Cars & Trucks
I started my car this morning and it ran fine for about 4 min. then died. try to start it again, and it wont fire off.
start simple check gas and fluid levels look for loose connections in wiring are you using remote starter? check for fuel pump noise have someone turn on the key while you remove gas cap listen for humming sound when ignition switch is in run note fuel pump will only stay on for 2-3 sec unless starting car
Jan 13, 2011 | Chevrolet Prizm Cars & Trucks
1992 olds 88 stalls. after it sits for a half
Is the Service Engine Soon (or Check Engine) light illuminated on the instrument panel? If so, then have someone pull the codes and post them back here. Autozone will do this for you at no cost.Caution: don't purchase any parts after reading the codes on their recommendation! If no codes, then suspect either a bad crankshaft sensor or camshaft sensor. There are other possibilities too, but these are primary. I have seen MANY bad crank sensors do exactly what your describe without setting a code.
Jun 21, 2010 | 1992 Oldsmobile 88
Car has been unused for two weeks. when i first started it up it ran rough. after a couple mins. it ran fine. drove down the street then it quit, would not start unless i held the gas pedal down as soon as...
The best thing is to take it to a parts store and have them check the codes. Im sure the check engine lite is on.But sounds like it might be choking itself to much.
Feb 23, 2010 | 2001 Chevrolet Cavalier
Truck ran fine, turned off for 5 min the it would
listen to see if the fuel pump is kicking on.
Jan 02, 2010 | 2002 Chevrolet Silverado 1500
Quits like fuel pump goes out but has good fuel pres new delco
i had the same problem and it died out of town got it towed and it was the fuel pump fuse and that was it they are famose for it
Jul 05, 2009 | 1991 Chevrolet Cavalier
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Changed the fuel injector on 95 Cavalier 2.2 moter. Car acts like it wants to start, but doesn't.
did you check you fuel filter and your fuel pump? i had the same problem and once i replaced the fuel filter its been fine since
Apr 18, 2009 | 1997 Chevrolet Cavalier
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
