Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
My FDB2810Ldc1 dishwasher
It won't start after door is closed, it just sits there for a minute and goes back off. when we had a power failure it reads ee instead of pf and can't turn it off. thanks gary
    Problem Solver:
  • 4 Answers
Gary:
This sounds like the power failure tweaked the computer inside the machine. It is just like a regular computer when it comes to power failures.
If it has a reset button push that. If not, find the fuse in the fuse box which controls the dishwasher and throw that for a few minutes, reboot the thing.
There can also be damage to the computer in the dishwasher from the power failure.
Lastly, there is a reset sequence for each of these computer but it varies by the manufacturer. On my Kenmore, it is 1)Press HI temp, 2) press Heated Dry, 3)Hi Temp, 4) Heated dry. Then wait for all of the lights to go on and most of them to go of. At that point press cancel. Others involve pressing Sani Rinse and high temp. Some random button pushing is in order, luck is with you.
Posted on May 13, 2008
Fdb2810ldc1 Power Failure with lights blinking
hi henry check the door safety switch they can cause goofy problems. good luck geodaws
Dec 09, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher heating element won't turn off
Hello niki4god - I recommend resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Jun 20, 2013 | Frigidaire 24 in. FDB635RF Built-in...
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
My GE quiet power 1 dishwasher has flashing lights and won't stop cycling, what do i do?
I have had this problem with this dishwasher in my rented apartment occasionally since I moved in. It would usually reset itself if I let it sit a while, but not today. Today all it would do is flash and beep and I finally just unplugged it. I stumbled across this page and read the post by Dyons above and it worked. Close the door, let it grind away and within 2 minutes it will reset itself. Thanks, Dyons!!!
Sep 28, 2011 | GE Dishwashers
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
My FDB2810Ldc1 dishwasher won't stop going thru the cycles. We have to open the door to stop it. When the door is closed again it starts and will continue for hours if the door is not opened again.
The first thing I would try, is to to reset the washer by unplgging it with the door open. You can do this by manually pulling the plug or by tripping the breaker that goes to that plug.
Hope this works for you,
RSMITH972278
P.S. IF YOU NEED FURTHER HELP CONTACT ME !
P.P.S. PLEASE RATE ME !
Oct 21, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 | Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Please help
try dropping power to the unit for a minute and see if it will reset itself. if not, you have a logic board failure. that or a door switch. check the manual for an indication on the warning alarm.
good luck
mark
Nov 18, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
473 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
