My daughter`s laptop e-systems EI 3103 boots up but nothing on screen, all buttons light, keyboard works, if you hold it a certain way you can just make out the password box to sign in, any ideals of what it could be??. Thanks
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 07, 2010
How can I free my pc from forgotten bios password?
try switching on the unit and holding down the delete button, This normall gets you into bios. When that opens arrow down until you get passwords , click enter and change the password setting to no enter then go to save settings.
Oct 23, 2014 | Laptronix Mini Pc Laptop Usb Mouse For...
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Have an acer aspire 5515 laptop. It will not boot. Tried doing alt-f10 to restore but it does nothing. Did not come with restore disks.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
don
Feb 22, 2011 | Computers & Internet
How do you remove the keyboard for e systems 3103 laptop to find the second memory slot
On the bottom of your computer you will find several small philips screws, holding small panels down. The memory slot is behind one of these panels. Research says there is one 512K module with a second socket for another 512K module, for a 1GB total. You do not remove the keyboard.
Sep 18, 2009 | Computers & Internet
Ei-3103 vista drivers needed
download AC97 sound driver for vista and realtech ethernet driver for vista these are the to most common,  and install them
May 04, 2009 | Computers & Internet
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
Aug 18, 2008 | Medion MD-40954 Notebook
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
