posted by sjanus on May 13, 2008
There was a paper jam and paper was removed. Message appeared "message in Memory / check drum cartridge". New drum cartridge was "dropped" into the machine as always, but error message remains teh same "Message in Memory/check drum cartridge"
Solution #1
posted on May 13, 2008
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for OKI OKIFAX 5650 Plain Paper LED Fax
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Programming Speed Dail numbers...
I just took over a job at the... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
