Question about Kitchen Ranges
Range does not work i put it at 350 degrees and it stays at 100 degrees checked the thernostat and it's not that
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
If its electric i would check continiuty on the elemnets or perhaps a faulty high limit thermostaton back wall of unit, if gas stove , most likely source of problem is faulty ignitor, check for 110v to ignito whrn on clicks on if you have power to ignitor and its not glowing thers your problem
Posted on May 13, 2008
Set oven for 350 degrees but won't heat stays at 100 degrees but the broiler works
you will need to check the oven probe replace it if needed,if that does not solve your problem then your will ned to replace the electronic control board if equipped
Dec 21, 2010 | Kitchen Ranges
The oven doesn't come close to keeping a REASONABLE temperature. It fluctuates sometimes 75-100 degrees. I'm not talking about opening the door and then waiting to re-establish the temperature it was set...
If you just bought it, have it replaced, or repaired under warranty. If it is an old oven, replace the temp probe first (if it electric) It senses the temp inside oven, It is the least expensive part of the fix. If that doesn't work, replace thermostat/temp control board. When you replace a board, you replace the probe too. It will be needed either way. If just changing the probe works, you saved yourself some money.
Apr 06, 2010 | Kitchen Ranges
My oven stays at 150 degrees at all times...even
clean pilot assembly. then oven thermostat
Jan 01, 2010 | GE JGBS20 Gas Kitchen Range
GE Self Cleaning Gas Range F2 Error, happens at 400 degrees and turns oven off any advice?
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Maytag MER5870 Electric Kitchen Range
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Sep 22, 2008 | Maytag MER5870 Electric Kitchen Range
GAS STOVE PROBLEM WITH OVEN ON "BAKE."
Check ignitor. It has to pull enough amps for the gas safety valve to open and light the oven.
Jul 17, 2008 | GE JGBP32WEFWW Gas Kitchen Range
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
