Question about Milton Bradley Ouija Board: Glow In the Dark
Will we be together? - Milton Bradley Ouija Board: Glow In the Dark
Help with Simplicity pattern 3894 Top C 2.With RIGHT sides together. 3.With RIGHT sides together. It is not clear on how to put RIGHT sides together on 2. and 3.
Just guessing here. Put the front & back pieces together with the rights sides facing each other. Stitch the shoulder seams, then stitch the side seams.
What Does Right Side Wrong Side Mean
Right Sides Together
Jun 18, 2016 | Simplicity Sewing Machines
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
How do you get headlights on a 2000 firebird in sync they will not open and close together???
Disconnect both together...turn on/off while disco...then re-connect both together...should put in sync...hope this helps.
Sep 20, 2014 | 2000 Pontiac Firebird
Then chain keeps falling apart
I imagine you have probably figured this out by now, but I'm going to go ahead and answer it anyway because when I searched for an answer to this question ealier today, I couldn't find one anywhere.
It is not initially apparent, but the chain pieces snap together. When you try to put them together, they seem to just loosely fit in place, but if you PUSH them together, they will snap together very easily and hold together without any problems.
Jul 03, 2012 | Viper K'nex Corkscrew Coaster, Vertical...
Got two cables and need to crimp them together to maintain connection. What do i need
You can use many things. There are **** connectors that you strip the ends and then crimp them together. You can also use a squeeze connector where you just place the wires together and then close the flap with pliers and it fuses the wires together.
May 20, 2010 | Cars & Trucks
I have a dayton 1 1/2 h.p electric motor, and need the wiring diagram for 460 volt. the part number is [1] 3n013bb. thanks
Line is L1 L2 L3 to line voltage. wire nut 4-7 together wirenut 5-7 together and wirenut 6-9 together connect 123 to line for low voltage 123 together 456 together 679 together. This works on all dual voltage 3 phase motors. Some of the newer Daytom motors have a plug that you just turn for changing voltage. Rudty
Jun 03, 2009 | Heating & Cooling
Will they work together?
I believe the models need to be the same in order to work together. They will work together but just how good is unkown till your try it.
Dec 06, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Milton Bradley Ouija Board: Glow In the Dark Logo
Top Milton Bradley Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Milton Bradley Toy Expert? Answer questions, earn points and help others
