Question about ASUS Eee PC 1000HD Netbook
I need to restore my netbook eee pc 1000hd to factory settings. how do i do that?
  • 52 Answers
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
Instructions from Acer
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
SOURCE: Asus eee pc 900HD running XP. need to restore to
OK, here is what you need to do, you need to get a USB - DVD dongle, either SATA or IDE. Similar to this at this link. http://cgi.ebay.com/USB-2-0-TO-SATA-IDE-ADAPTER-CABLE-4-DVD-CD-HARD-DRIVE_W0QQitemZ220544495390QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item335979ef1e#ht_4098wt_1152 Get your recovery DVD, put it into the DVD. Then, set the eeepc to "BOOT" from removeable media. The PC should then boot of the DVD and you can then install OR repair the install. I have included a link that gives you a step by step. http://www.sampletheweb.com/2008/01/05/installing-windows-xp-on-the-asus-eee-pc/
Posted on Jan 22, 2010
SOURCE: asus eee pc 1005hab netbook how to restore
You need to connect an external DVD & insert your dvd disc, that came with your unit, set it up in BIOS to "Boot from DVD" and restart the PC, when it Boots off the DVD simply follow the instructions to completely reinstall your Operating System.
Posted on Jan 27, 2010
walesarumi
  • 6993 Answers
SOURCE: I need to restore factory settings on my Compaq
to reset your laptop, restart your computer and constantly press F11 once the first black screen on your laptop displays, or the Compaq logo display. Your computer will automatically load to recover manager and you can factory restore you computer from there.
2nd option: click start menu, click all programs and scroll to "Hp backup and recovery" or "Backup and recovery" click it and proceed for the factory default setting.
Good luck.
Posted on Apr 18, 2010
SOURCE: how do i reset a eee pc 901
To reset my 901 XP, I remove the battery as shown on page 3-3 of the instruction manual.
The reset button can now be accessed: it is a small shiny metal
plate, about 3mm by 15 mm located on the left of the battery compartment (closest to the LAN port).
Press the metal plate once with a ballpoint.
Posted on May 12, 2010
RESTORE asus TO FACTORY
This WEB site will giuide you in restoring your ASUS notebook back to the factory setup.
http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings
Apr 18, 2012 | ASUS Eee PC 1000H Netbook
ASUS Eee PC 1005HA-PU1X-BK Netbook how do fix black screen issue?It has an upper left corner blinking dash_
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jun 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hello, I have an ASUS Eee PC 1000HD with windows XP. I need to get it to its original settings. I tried rebooting it and pressing F9 and it didn't work (previously I changed the reboot settings...
you can press the switch on the system and press F8 and F10 key with a small interval.so that you can go to the safe mode.on the safe mode you will have the options to restore your system.For more details feel free to contact me
Jun 09, 2011 | ASUS Eee PC 1000HD Netbook
I need to restart the netbook to go back to factory settings
You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
Jan 24, 2011 | ASUS Eee PC 1000H Laptop
How can i get Asus Eee PC back to factory settings?
Hi. Actually when you restore your system to its factory settings it will restore everything on your computer including the original operating system, but if you're saying that you have installed windows 7 on it then try going to ASUS driver support website, just type in their the model of your machine and it will ouput every software and drivers available for laptop and also different versions of operating system, So just choose the correct OS version for your laptop. Hope this Helps
Jun 04, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 1000HD Netbook Logo
894 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
