Question about Refrigerators
The alarm is beeping and the freezer temp is flashing along with a flashing dot with half circle shapes around. The fridge also seems to be not as cold as should be. Thanks
  • 1 more comment
  • pfjt_martin Sep 06, 2010
    thanks, the fridge is a Westinghouse RS643V, does this change your diagnosis at all? do you know what the optimum freezer and fridge temp should be?
    Thanks, the fridge is a Westinghouse RS643V, would this change your diognosis? What would the optimum freezer and fridge temps be? thank you
    Thanks very much for your advice. Will give it all a go!!
  • 11,800 Answers
You haven't told us what is the exact model of your device so this is just an educated guess: the dot with half circles signals the fact that the compressor isn't working, the alarm is beeping and the freezer temp is flashing because the temperature is way too high. Make sure the temperature settings are ok; if they are that means that the unit is no longer capable of delivering them - something has failed. Call a repairman, there's nothing more you can do, the unit must be checked by a pro..
Posted on Sep 06, 2010
  • Azrael SRL Sep 06, 2010
    In the freezer the temperature should be set at -18C and in the fridge at +4C. The blinking 3 half circles around a dot signals the fact that the Quick freeze should be activated.
    Set the temperatures correctly , activate the Quick freeze and put inside some freezer thermometers - $5 at any superstore - to check that the required temperature is really reached. If it's not then something is wrong with the control board or the compressor.  Take everything out of it, let it defrost completely and try again. If it's the same then call a repairman, there's nothing more you can do, the failed parts must be replaced by a pro.
  • khansafiq
    khansafiq Apr 16, 2013
    Hi Mate I have the similar problem coupled with Frozen vegetable in the Crisper, I defrosted the fridge and found the beeping is there and the fridge is not cooling hence replaced the DEFROST Thermostat (RS643V called Defrost Terminating Thermostat (DTT at 11 Deg C). Still it seems that the Freezer is not getting cold to -18 Deg is it because the Temperature Sensor is defective? Any help would be appreciated at Khansafiq@hotmail.com
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Maytag refrigerator is not cooling and the temp alarm is flashing and beeping
hi so if your refrigerateris too hot try putting a bag of ice and frozen food into it and take it back to the manufactuer and tell them what is wrong with it
Aug 10, 2012 | Maytag (MFI2568AEW) Bottom Freezer French...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
Refrigerators Logo
327 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
