Question about Canon PowerShot SD600 Digital Camera
Hello, Up until 2 days ago, I was able to start my camera and use it easily. Now, I cannot start it because there is a message that says "Lens error, restart camera." What should I do? I really like my camera and JUST bought a new memory card for it today, although this problem has been happening since yesterday. Thanks for your help!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SOURCE: Memory Card Errors with Canon PowerShot S3
I have the same problem with the 2GB card. I recently used it in my computer so i figured thats the problem. Dont put them in your comp.
Posted on Feb 20, 2008
SOURCE: "Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Posted on Apr 20, 2009
t00nz
  • 4738 Answers
SOURCE: Lens Error ixus 800 is
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Aug 02, 2009
  • 336 Answers
SOURCE: Camera wont turn on: lens error, restart camera
Your problem is common to that model and actually to most of camera models. Usually it has foreign materials interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. It's also possible that the camera has been powered on, but the lens had been blocked preventing its extension which eventually damaged gears or other parts. You should also check if your battery has enough power to supply the lens mechanism, easy way to find out is to use a new charged or brand new battery.
If you are still under warranty, I suggest to bring you camera to the store or service center. If not then here are some things that you can do to try to correct it. I hope it will work for you.
Regards,
Jeep Brainy
Posted on Aug 11, 2009
SOURCE: canon powershot A590 displayes lens error, restart camera.
I had this problem. Nothing was lodged between the body and lens, restarting multiple times did nothing, cleaning, torquing, twisting over several days - nothing.
So, figuring "what could it hurt?" I just smacked it on the heel of my hand a couple times. Now it works.
firm percussive maintenance saves the day once again.
Posted on Jan 19, 2010
I have a canon ixus 860 IS and i it was functioning well until about 2 days ago when suddenly there is a sound upon starting/turning it on that doesn't seem to sound as smoothly as before. and just...
Hi,it's look that is yourfocus motor or
the ccd are defective it is always the same problem whit this kind of camera.
you will to fix the lens and ccd
hope it is not the ccd....
have a nice days
Apr 30, 2010 | Canon IXUS 860 IS Digital Camera
CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Mar 26, 2010 | Nikon COOLPIX L18 Digital Camera
Sony DSC W30 digital camera, lens unit problem
Hi!
If you're sure you didn't damage the lens flat cable which connect to the motherboard, the focus of the lens unit you bought on ebay doesn't work. You can simply replace the back part (with focus) of the new lens unit with your old one. It requires soldering.
Tom
Mar 06, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Get ERR message when trying to take pictures/troubleshoot no help
Two possible things to check.
First, a bad memory card can easily cause this problem. Try replacing the card.
Secondly, could be a poor connection between camera and lens. Be sure contacts around the rim of lens and lens opening are clean and free of dirt, dust and debri. Do not get anything inside your camera when you remove the lens. Dust is a killer to the sensor in the camera.
Mar 22, 2009 | Nikon D50 Digital Camera
Nikon Coolpix s210
Hey SandyG1019,
If you just purchased this camera 2 weeks ago it might still be within the retailers return/exchange period, and I would suggest you just exchange it for a new one. This error message should mean that something is obstructing the movement of the lens (i.e. sand), but could also be do to a problem with the lens mechanism itself. If you choose to try and resolve the problem you could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. This being said I would suggest instead having the camera looked at by an authorized service technician since the camera is most likely covered under a manufacturers’ warranty, and the repair would most likely be free. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 29, 2008 | Cameras
Lens error messages
Looks like the only thing to do is send it in for service, which if it's out of warranty is not very cheap. Or you can sell it on ebay or craiglist and use the money to buy a comparable one.
Good luck,
Lee
Jun 15, 2008 | Kodak EasyShare C613 Digital Camera
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
