Question about Sony Cyber-shot DSC-S600 Digital Camera
It is not focussing & error E:61 displayed on screen
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 06, 2010
Testimonial: "thanks it works"
Error Code on DCR22E E:61:10 Code comes up immediately recording starts screen turns black & turns off. Any clue how to solve this or has this died?
hi,
1) this is lance problem ,the error 61:00 shows lance error
2)open your camera body carefully
3)you must be careful when you remove the cables of lcd and other one
4)now you see lance asambly , remove the lance asambly and clean contact properly and fix it back
this will 99.99% help you to remove this error otherwise tell me more i will solve your problem
thx for reading
May 28, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Blue screen is coming with 5e02 erroe
Hello Sanjay -- NOT a good sign I'm afraid the 5E02 message is a PCB error.
I just checked a website for a manual with trouble shooting ideas to send you and the sites are full of 5E02 problems and the only solution appears to be - Take it back to a shop if under warrantee.
Problems were UK , USA & Australia -- (I use www.google.co.uk ) as my search engine and i typed
"olympus 5e02 error message" and it applied to non-focussing problems , no display etc
http://www.howtomendit.com/answers.php?id=120514
Here is one link as example -- Ray
Jan 14, 2011 | Olympus Stylus 710 Digital Camera
How do i bypass the ink cartridge error on the hp Deskjet F4480? It is saying ink cartridge not compatible but it is a genuine cartridge. And E is displayed on the screen and the light is flashing. How can...
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
May 20, 2010 | HP F4480 All-In-One Printer
I have error code E:61:10. Any suggestions?
HI there error code E:61:10 means
E:61:10 Zoom operations fault Inspect the lens block zoom reset sensor
Hope you understand. Thanks & waiting for your feedback.
Mar 24, 2010 | Sony Handycam CCD-TR818 Camcorder
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Hi fi wont turn on !
hi. im assuming its a technics / panasonic system judging by the F 61 error code? try testing the cooling fan at the rear (assuming it has one) i once had the same error code on my technics amp and it turned out to be a faulty cooling fan. after replacement out of a scrap unit, the amp worked perfect.
Aug 07, 2008 | Audio Players & Recorders
E:61:00 Focus Error
Hey peter grifin,
Sony actually calls resetting the camera initializing, and to initialize the camera first take the battery out for about one minute and then reinsert the batteries. Next you want to go to the setup menu and find initialize and press the up arrow to OK and press enter and a message should appear saying "initialize all settings ready?" now press the up arrow back to OK and press enter. This process should reset your camera back to factory settings. If this doesn't work you could bring the camera in to a Geek Squad® precinct at a Best Buy™ store, and they should be able to send it out for service.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Image not visible on screen; but able to take snaps
press the "disp" button once or thrice.
if no display comes take it t service centre
Oct 31, 2007 | Canon PowerShot A540 Digital Camera
Sony DCS-T1 digital camera
I'm sorry to give you bad news, but acording to the manual, an E:61 error means that it must be repaired by sony. I hope your warrenty is still viable.
Mar 24, 2006 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
175 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
