I have a john deere L110 auto , fitted with a kohler eng , it keeps blowing the starting fuse , 20 amp ,all after 5 to 10 seconds of running , i have checked the alt /stator , regulator , wiring , micro switches , etc , can you tell me what else can cause this problem,
  • 246 Answers
SOURCE: My 17.5 Kohler engine runs for about ten minutes
Hello wesleyhann:
This Sounds like a Stator/Charging Coil or Voltage Regulator Problem.
>>Go to this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=bkP1h4rj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjksMjkmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1DaGVja2luZyB0aGUgQ2hhcmdpbmcgU3lzdGVt&p_li=&p_topview=1 and Use the Information and the Test Chart Links to Properly Determine the Charging System on your Engine and Correctly Test the Charging Sytem to Determine if it is Charging Correctly. These Charts and the Testing can be Used for Almost All Small Engine Charging Systems (Kohler, Tecumseh, Honda, ect). This Site Addy; http://www4.briggsandstratton.com/miscpdfs/RNT/alternator_id.pdf will Assist you in Determining you Charging System on this Engine.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
backwoodsctr
  • 169 Answers
SOURCE: I have a five year old JD L110 garden tractor that
need to ohm out the clutch....clutch ohms are 2-4 ohms anything less will blow the fuse due to it being shorted out,,,,,takes less than a min to find out with a multi meter
hope this helps
Posted on Nov 21, 2009
SOURCE: HI, My name is Eddie.
To blow a 20 amp fuse, or any fuse for that matter, one, must have a major short circuit somewhere? So you need to find this first. It is always inadvisable to simply replace a fuse, especially with a larger size, before first finding what caused the fuse to blow.
You need to find out what is fed by that fuse, and trace back along that circuit and locate the short. It maybe, say, an abraded wire touching the chassis or earth? or it maybe a faulty component? It's impossible to tell without examining a unit.
You will need to obtain a service manual to be able to read the circuit diagram to trace it out, below is a link to hopefully obtain one
http://bobcat.servicemanualvault.com/
Once one has located the short, or faulty component replacement will usually fix things, or if a short to chassis, re-insulating the affected area will usually solve things.
Posted on Aug 01, 2011
  • 6468 Answers
SOURCE: John Deere L120 blows fuse when starting. Starter spins very briefly, then 25 amp fuse blows
one of the safety switches could be shorted out internally
Posted on Apr 10, 2012
Lx173 John Deere wont start. starter motor will not run to start eng you hear only solenoid engaging starter drive. have tested motor on bench. started blowing fuse since solenoid replaced.
You may have a bad key switch or you have a short in the wiring somewhere. Also check the Magneto's for proper gap. If they are loose they will stick to the flywheel and prevent motor from turning and could blow fuse.
Oct 21, 2016 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
Why is my John Deere L110 17 1/2 firing but not starting. It pops like a gun shot
this could be a engine timing problem this model should have a 17.5 hp kohler engine , now kohler's are now famous for having coil problems cus of overheating it and the other cause could be if you reciently shocked this engine hard (Heavy load) sometimes the flywheel pully (iron thing on top) comes loose or you shear the keyway on shaft anyways ck out my youtube video on easy way to change kohler coil for help doing this (all you need is 6 mm wrench , two hands and a playing card)
Apr 24, 2014 | John Deere Garden
John deer L110 17 1/2 Kohler engine fires but doesn't start, it just pops like a gun shot
given the info available , it sounds like either a hole in the piston or a burnt/stuck valve. the popping sound could be a backfire, from improper detonation of fuel ,a simple compression test will tell if this is in fact the problem.
John deere diagrams
Howdy. Email me. Have a PDF.
< ohpedro@hotmail.com >
Nov 04, 2013 | Garden
John Deere L110 what is the 20 amp fuse for?
Hi. That 20A fuse is basically the main fuse. But what is year model and is engine Kohler or Briggs & Stratton? It may depend on the above, but on an L110 the circuits that need to be protected are mainly the Charging Circuit, the Operator Presence Safety Circuits, and power for the Fuel Shut-off Solenoid which is under the carby fuel bowl. If the fuse blows the fuel shut-off solenoid will close and after a few seconds the engine will stop. But even if the engine could keep running the safety circuits would respond as designed and earth out the magneto and that would stop the engine. The engine has an AC "alternator" under the flywheel and a rectifier/regulator which changes the alternator's output current from AC to DC and then regulates it to suit the battery's needs. Depending on engine model this charging system may have up to 16A capability, so that is why the fuse is 20A.
Hope this helped
Pete
<ohpedro@hotmail.com>
Nov 03, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a five year old JD L110 garden tractor that just started blowing the inline 20 amp fuse that is directly connect to the positive side of the battery terminal, when the fuse blows it melts the entire...
hope this helps
Nov 21, 2009 | John Deere Garden
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
