If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test.
Probably too old being 2001 vintage.
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Hi, The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck, In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment. Hope you will understand my sayings. Thanks for using fixya.
Sony camcorders C:31:23 error Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. good luck
please mark the post with a fixya
