Question about Panasonic KX-TA62470-2 (KXTA624702) Expansion Module
Kxta624 problem with programming jack #01
All jacks work properly except for the intercom. when i plug in a programming phone into jack 01 to view the programming there is dial tone but no display. any troubleshooting tips? have tried powering down system already.
thanks
    Problem Solver:
  • 3 Answers
Need more information I am a panasonic dealer--does the display work doing normal phone use. Are you just having problem with getting into programming or problems with port 1
there is no switch on the 624/824 you go into program with the phone which model phone are you using on port 1. If this site allows it write direct to me at nspear@verizon.net or call me
(201) 757-1632
Posted on Aug 03, 2008
    Problem Solver:
  • 8 Answers
I do not have any 824's in my network - I do know that on the 616 there is a set/program or run/program swith on the KSU that MUST be set to program before any work can be done on the first port
Posted on May 22, 2008
How do I program a norstar t7316e phone to call long distance?
Unless "Set Relocation" is turned on (usually is / should be OFF), plugging a set into a different jack gives it the extension # and programming of that jack. Press Feature * 0 and an Intercom key to find out what the new extension # is, and program that extension to allow long distance. Or change the cross-connect to physically put the old port on the new jack.
Sep 12, 2014 | NorStar T7316E Corded Phone
How do I get the "Tel to" ( the line hookup out the back of phone for a cordless) line to work on a KX-T7433
You need 3 things, wiring, programming, and a cordless phone.
There needs to be a 4-wire connection from the TD system, you need to turn on the XDP port in programming, and you need to have a single line device. You can test the first thing by unplugging the digital phone and plugging the cordless phone directly into the socket. If it works, then you have the proper wiring. Now, in programming you need to enable the Jack in 600 and make sure the 39x code on the intercom says unmerged. I don't remember which is which, but I'm guessing (50-50 chance) that 390 makes the XDP stand alone.
Carl
Sep 30, 2010 | Panasonic Lands Phones
How do I change the time for daylight savings on a Panasonic KX_T7731?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
1. Push PROGRAM key
2. Dial "0"
3. Enter year (last 2 digits)
4. Enter month (01-12)
5. Enter day (01-31)
6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.)
7. Enter Hour (01-12)
8. Enter Minute (00-59)
9. Press 0 for AM 1 for PM
10. Press "AUTO DIAL/STORE" key
11. Push PROGRAM key to return to normal mode.
Mar 15, 2010 | Panasonic KX-T7731 Corded Phone
What is the feature code for Night and Day on a PANASONIC kxtes 308 Telephone System
From the phone connected to Jack 01 (usually 101) try 780# for DAY and 782# for NIGHT on the intercom.
Carl
Sep 27, 2009 | Panasonic KX-T7730 Corded Phone
Intercom light stuck on and no dial tone on GE 4 line phone
You may need to assign an intercom ID for that unit by pushing one of the intercom buttons at the top.
Dec 05, 2008 | GE 2-9450C Corded Phone
I have a panasonic kx-ta624.I have a anolog line coming into port CO1 and feeds all the jacks my problem is i can make calls but cant recive them. I am not using panasonic phones but was told the system...
You have to have ONE 7x3x phone plugged into Jack 01 in the system or you don't stand much of a chance to make this work.
There is no USB interface to program a 624 and the ringing is controlled by programming. By default, turning off the system will tie CO1 to Jack 01 in power fail transfer. If you believe the line is functioning, then plug it into CO1, a phone into Jack 01 and call your number. If it rings, then you have connectivity, now puwer up the system and do the same thing. If it doesn't work, then you need to program the box.
Carl
Sep 08, 2008 | Panasonic Lands Phones
I am unable to change the time on my phone to reflect the day time savings
You will need to enter programming mode. Here are the directions.
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by setting the switch on the end of a display phone to PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
  1. Set switch on end of phone to "PROGRAM" (or push PROGRAM key if you have one)
  2. Dial "0"
  11. Return phone switch to "SET" (or push PROGRAM key if you have one)
Mar 22, 2008 | Panasonic KX-T7730 Corded Phone
2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Sep 26, 2007 | GE 2-9450C Corded Phone
How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Sep 14, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-TA62470-2 (KXTA624702) Expansion Module Logo
1,353 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
