Transfer VCR to DVD
Disc's recorded on this unit will not play on any other make,cannot find any info onfile type .VRO
I want to transfer VCR tapes to disc
  • 78 Answers
When you record something on dvd you have to do what is call "finalize" or "finish" to be able to play on another dvd player. look in the menu of the unit and find a section that has one of these words. you can this to happen manually or automatically when the recording is complete. it can be a little complicated sometimes.
Posted on May 13, 2008
Can you still hook up a DVD & VCR Recorder through Rogers PVR and record to disc anything you have on the PVR memory to a disc to have a hard copy to keep and free up space on PVR memory????
I think you will have difficulties with DVD or Video tapes that have imbedded copy right signas l if you feed the video cable from old device into PVR s input source. You may find the PVR will refuse to record due to copyright . Does the PVR have a USB port you may be able to plug in a 20 Terabytes USB portable drive into it . I am not familiar with the rogers PVR but check its manual to see if it can.
you may be able to convert the DVD or Video Tape into an MPEG -2 or MPEG -4 format and read it on the PVR using a computer.
Copyright law may allow you to convert the type of media (you must own the rights to use original copy) to another format of media (PVR) for your use only. Check if copyright in your country allows this in Australia it is covered under https://www.comlaw.gov.au/Details/C2004C01235
also see
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/how-to-transfer-vcr-video-to-dvd-preparation
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/rip-import-copy-vcr-vhs-video-and-burn-to-dvd-with-nero
Aug 14, 2015 | Televison & Video
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
Re v5500 . . . can i copy a movie from the vcr onto a dvd with this model???
You cannot transfer VHS to DVD on this model unit by itself. You can, however, connect the AV outputs of this unit (as a VCR) to the respective AV inputs of a separate DVD recorder - using yellow-white-red RCA cables - as long as the source tapes are not copy protected, and the appropriate disc formats for the DVD recorder are used.
Apr 20, 2011 | Samsung DVD-V5500 DVD Player/VCR
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
How can you transfer vcr movies to dvd's through the sylvania rwi-r device? thank you!
I connected my VCR player to my DVD recorder with a stabilizer filter; (a little black box) sometimes called a Digital Video Macrovision Stabilizer. These cost about fifty bucks. Play the tape hit record on your DVD recorder.
It's worth mentioning that this takes a while an eight hour tape takes eight hours to record.
May 16, 2010 | Computers & Internet
Connect a dvd-vcr recorder to my tb
you will need an external dvd recorder to record vcr tapes to dvd. Sometimes you will have problems with quality when you do it this way. I have transfered vcr tapes to dvd with a transfer device using the computer and got much better results. If you need the name of the transfer device just get back with me and I will get it for you.
Feb 11, 2009 | Sanyo DS27510 27" TV
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Failure in tape to disc transfer
what kind of software are you using. I have had problems with this type of transfer and I had to use a special transfer device. If you want to know about the device write back and I will tell you how I did it.
Jan 07, 2009 | Lite On LVC9006 DVD Player/VCR
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Oct 07, 2008 | Philips Televison & Video
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
