Question about Thermador SC302T Electric Double Oven
Did self cleaning option and when cleaning was complete oven did not unlock......tried turning the power on and off to see if it would release did not work.
  • 944 Answers
Cooling time has elapsed so this problem will occur.
Try these steps to solve the issue:
1)Unplug the unit or shut off the circuit breaker for 10 minutes. Plug the unit back in.Set the clock and gently try moving the door lock lever try Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever try opening the door.
If still the problem persist you have to manually open the lock.
There is three types of lock that will occur.These locks
1)Heat sensitive lock
2)Motor controls the lock
3)Solenoid lock
Solenoid lock is located at the back of the range.Remove the rear panel.
Solenoid coil Failure will cause the unit to lock.Do continuity testing on the solenoid coil and check its working.
A motorized or heat sensitive style lock will usually be located beneath the cook top on free standing ranges. The cook top would usually need to be lifted to access the locking mechanism.If the motor controls the lock then do continuity testing on the motor coil.and replace the motor accordingly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
2 Suggested Answers
  • 1417 Answers
SOURCE: MY self cleaning oven door will not unlock. Have tried to reset it. But it won't release
Hello.
What you need to do to solove the problem of the oven first of all carefull out off the oven from the power supply for some time then allow it to cool it self down for some time.
PLEASE note this dot not force the oven open after the first instruction above .
Then plug the oven back to the power click on the reset button,then after that you can then click on the open button and the problem is solve.
Thanks.
Posted on Nov 17, 2011
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
I used the self cleaning option and cleaned the oven now that the cleaning process is complete the oven will not heat up. the clock/timer just above the oven door works but it will not heat up at all. What...
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Door stuck after cleaning cycle? Can hear latch release but door will not open. Power still good. Oven still works, just can't open door,
heatman101
Sep 16, 2010 | Whirlpool GMC275PD Electric Double Oven
Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
heatman101
Apr 27, 2010 | Thermador SC302T Electric Double Oven
My oven door will not unlock after cleaning
It will take some time for it to unlock. The lock after self cleaning is controlled by temp. The temps during self cleaning are over 900 degrees and after self cleaning it will take several hours before the oven lock will release. Don't try to force. If after 3 hours it has not unlocked you can try disconnecting power for 2 minutes then reconnecting to activate the self cleaning motor assembly. Good luck and thanks for using Fixya
Feb 23, 2010 | Kenmore Ovens
Oven would not release
heatman101
yyeeyr
Sep 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven won't unlock after cycle is complete
Unplug it for about 30 minutes, plug it back in and see if it unlocks. If not, then the latch, interlocking microswitch or control board is faulty. Also look for any bad connections (make suer the power is off before you start wiggling connections).
May 21, 2009 | Ovens
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
94 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
