This is usually caused by a failed component in the moisture sensing circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
SOURCE: Please wait -Condensation operation Paused
Always happens when I go to Scotland to visit my daughter.
Solution - I take it to bed pugged in & switched on. It's so warm in the morning it works!
pootle 1944
SOURCE: Condensation
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
SOURCE: condensation operation
I found instructions with pictures on fixing this problem online at
http://www.freewebs.com/ltooz/03jvcgrd70u.htm
The process involves taking the camera apart.
Other forums I have looked at have mentioned waiting the error out or allowing the camera to air out.
SOURCE: camera says condensation please wait
1. There is a condensation sensor in the tape compartment, It is a silver spindle, in the left rear. Clean this with a swab moistened with isoprpyl alcohol. I have tried this recommended approach, and it did not resolve the issue.
2. Open the camera, and unplug the power cable. This will reset the camera, and resolve the issue for varied amounts of time. The instructions for doing this are posted elsewhere on this site. I have done this with my JVC GR-D30, and have had success.
SOURCE: Please Wait Condensation, Operation Paused
This is often referred to as DEW and is a sensor inside the camera that detects moisture. You can hasten the removal most times by warming the camera with a hairdryer on medium setting and not too close to the plastic case. When you store the camera store it with a few of those little bags of silicone crystals that come in many packages that we just throw away.
Please rate our help to keep the service online
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
