Question about Fisher and Paykel Washing Machines
Gw711 fisherpaykel, not turning, filling up and draining ok, not agitating either
  • 343 Answers
There are a number of faults which can cause what you describe.
F&P machines have a self diagnostic code which will tell the most likely course to follow.
A failed component can cause problems with other components, so it's best to call a tech who can diagnose and test the parts before replacing them needlessly.
A techs work should be covered by a warranty, which self installed parts are not.
F&P machines should be thoroughly tested before parts are replaced so that secondary faults don't appear.
Probably not what you wanted to hear but the best course to follow in the long run..
Good luck....Nomess
Posted on Sep 06, 2010
My fisher and faykel washer model wa37t26gw2 does not fill, and will not drain. diagnostic says plugged drain hose, but it is clear from pump to diverter
Your question does not make sense. You say it does not fill but then you say it will agitate. How can it agitate if no water has filled? Does it beep and give an error code/ If so what is the error?
Jul 23, 2016 | Fisher and Paykel Washing Machines
Washer will not Agitate?
Had to send mine to repair for the same issue. They claimed a computer was malfunctioning. There was also an interlock that kept the agitator from engaging. Cost was nil for me because it was under warranty.
Jul 31, 2014 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
My washer is not draining or spinning. It fills & agitates. whirlpool LLR8245DQ0 . i LOWERED THE DRAIN HOSE AND DRAINED IT BUT IT STILL DIDN'T SPIN
It may be the wire from pressure switch is either not receiving power through the switch or it may be broken? If that is ok then check timer.
Jul 29, 2009 | Washing Machines
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Kenmore 24732 Top Load Washer
No agitate and no spin
ok,,you need agitator dogs ,,the top auger move booth direction,,worn agitator dogs,,,i need you to fill unit on smal use a poy or bucket i have to know if this washes,,,onthejob
Jan 16, 2009 | Whirlpool Washing Machines
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
