Question about Marantz SA-11S1
Marantz SA 17 CD-SACD player now unable to read SACDs. Problem started with hybrids (unit still played single-layer SACDs) but has now gotten worse-- unit won't play any SACD, single layer or hybrid. Will appreciate help. Thanks.
3 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: My Marantz SA-11S1 sacd player
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the hybrid SACDs and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to relapse the same.
ok
Posted on Mar 08, 2011
Testimonial: "Thanks for the prompt answer and "to the point" orientation. Thrustworthy Service!"
I reported the problem and Marantz Service replaced the whole transport. This is a issue known to them and this is the only solution. It works!
Posted on Jan 09, 2012
Sacd 1000 lazer alignment
There is no alingments to laser assembly. If it found faulty, must be repalced.
May 20, 2012 | Philips SACD1000 CD Player
My Marantz SA-11S1 sacd player can't read many hybrid SACDs anymore. Do you recommend lens cleaning? Help please...!
hi,
ok
Mar 08, 2011 | Marantz SA-11S1
It no longer reads all cds sacds it use to, thought cds were bad,bought second cds and still will not play help love the sounds
When you say it doesn't read SACD's do you mean it doesn't put out 5.1? Keep in mind that you have select the SACD multichannel area and use the 5.1 analog outputs for that and NO digital output will be produced.
The manual...
http://www.retrevo.com/support/Marantz-SA8260-manual/id/511bh850/t/2/
Dec 28, 2010 | Marantz SA8260 CD Player
The sacd player was working fine. But now will not play them. Using optical for sound hdmi for video. Played around with different settings but will only read the cd portion of the sacd. Any ideas? like i...
Your PS3 may actually be playing the SACD layer but if you're listering through optical you're not going to get any better sound quality than CD.
For stereo SACD quality you can use the analog outputs; for multichannel SACD quality you'll need to use HDMI.
See the PS3 SACD FAQ.
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
Will no longer play Red Book CDs - says either
just replace the ribbon wire of your cd player or check lense.by. jhuntech17
Oct 26, 2009 | Marantz SA-11S1
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz SA-1 installation question
Does your Marantz have an "optical" or "digital" out?
If so, use them. Assuming you have a quality receiver/pre-amp/amplifier it will have it's own D/A converters.
If you plug into the receiver's CD inputs you will be using the D/A converters in the Marantz.
If you plug into the DVR/SACD inputs - it depends on the receiver et al.
Try both. See if one sounds better. Select the one that sounds best. For a top-notch system you need high quality from cables to receiver, and speakers. You system can only be as good as your weakest link, so what sounds good/great to your ears, that is the best!
Cheers
Mar 27, 2009 | Marantz SA-1 CD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
218 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
