Question about Actron Digital Multimeter Tester
I need a use's manual for a craftsman multi-meter 82026
So if could be I bot a faulty pump two weeks ago
That can happen, especially today with "made in china" (or wherever) parts. Do or have some electrical testing done before you condemn the pump though. Is this a fuel pump?
YouTube has videos on electrical testing of the fuel pump circuit. You will need a voltmeter. A digital volt-ohm meter (DVOM) is a multi-meter most used in auto testing. A Fluke brand is most expensive, but many brands are quite inexpensive. I have used a Sears Craftsman multi-meter for several years, only paid about $30 for it-works great.
Is the pump inside the gas tank? Then definitely do the electrical tests to see if your pump is the problem.
Oct 31, 2016 | Cars & Trucks
Oven heats up, but then turns off
either bad igniter or bad oven safety valve check with multi meter. for continuity. beware that the igniter can check ok with multi meter but still fail manually as it may not put out enough current to run heat and ignite flame. u may also have a bad oven sensor? which turns off heat prematurely agin check with multi meter
Mar 08, 2015 | GE JKP27 Electric Double Oven
1988 Dodge Omni no dash board lights
Hi Beverly,looked everywhere for a diagram to your fuse box with no luck,if your able to afford a repair manual here is a link,I have one to each of my trucks.
Dec 07, 2013 | Jeep Cars & Trucks
Craftsman model 137.216100
Maybe the brushes are stuck.
Aug 29, 2013 | Home Security
CRAFTSMAN METER 82014 MANUAL
Please type in "Sears Parts Direct" on your computer, you will get a website, and a phone number.
Give them a call.and perhaps they can help you.
Jun 25, 2012 | Measuring Tools & Sensors
I need an instructions booklet for my hdm4400 digital multimeter
most multi-meters have its generic functions resistance, potential, etc. your manual is for extra padding in the box it came in. but if you are in need of a multi-meter then your technical knowledge should far surpass the multi-meters manual.
Jun 11, 2011 | Measuring Tools & Sensors
I need to creative lab sound blaster driver model sb0200
Copy and paste the below URL to your address bar.  Select your card and click the next button.
http://support.creative.com/Products/product_list.aspx?catID=1&CatName=Sound+Blaster#
Jun 03, 2011 | Creative Labs Sound Blaster Live! 5.1...
Actron Digital Multimeter Tester Logo
797 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
