Question about Hunter Dryers
We had an electrician install a Hunter ceiling fan in our daughter's bedroom along with a Hunter remote control. The light will randomly turn on in the middle of the night. It seems to occur only when the fan is running. We noticed this almost immediately after the fan was installed and replaced the remote control unit, however the light still turns on occasionally. On at least one occasion the fan was running and turned off with no other input. We do have several other fans in the house with the same remote control, but the DIP switches have unique settings and the light coming on happens at times when no other remotes are being operated (i.e. at 3:00 am in the morning when everyone is asleep).
  • 377 Answers
Before I did anything else I would try changing the code on the problem fan. Change the dip switches in the fan and in the remote controller unit to a different code. It is not impossible that a neighbor has the same code in their unit or a device in the area is operating off the same code. Probably the cheapest thing to try next.
Posted on Sep 06, 2010
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
255 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
