Question about Cuisinart DCC-1200 Coffee Maker
Where is the clean button on the coffee maker?
    President:
  • 1,335 Answers
There is no clean button.
To clean the scale buildup in the water system, you need to run a couple of cups of clear vinegar throught the system, run 24 cups of water (2 brew cycles) through the system to flush.
If the buildup is severe, you can substitue a calcium cleaner like CLR (Calcium-Lime-Rust) cleaner in place of the vinegar for a more aggressive cleaning.
Depending upon the hardness of your water, you need to do the cleaning every 30-45 pots of coffee.
Let me know if you have any other questions. Thanks.
Posted on Sep 06, 2010
I turn on my Mr. coffee maker and it just beeps and won't brew any coffee. What could it be?
Tried to clean it, everytime you press the brew button it just beeps and if we try to set it to clean it sounds like it tries to turn on but nothing happens.
Apr 27, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
It was time to change the filter and clean the coffee maker-I changed the filter and cleaned the coffee maker and now it will not work
You didn't say how you cleaned it but changing the filter shouldn't render it inoperative there is a reset button to reset the change filter timer but that shouldn't cause it to fail..Need more info.
Nov 28, 2010 | Kenmore DCC-KE12 Coffee Maker
Self-clean button keeps coming on
Unplug the coffee maker for 1 hour or longer - it wil lreset the machine, and turn off that self-clean light.
Feb 07, 2009 | Cuisinart DGB-600 Coffee Maker
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
How to get the clean off an ge coffee pot?
To clean the coffee stains there has a magic cleaning tools--magic melamine sponge. Magic sponge just need water and don't need detergent , strongcleaning capacity,saving time ,energy,convenient. The most distinguish with the traditional cleaning sponge is that the magic melamine sponge adopts physical cleaning principle. During cleaning, it can automatically absorb the stains on the surface. It is like countless superstrong mini cleaners working together.
When you use the magic melamine sponge to clean the oils on the dish you just need to follow below steps:
Step 1:put the magic melamine sponge into water,
Step 2:then use the hands gently squeeze the excess water in the magic melamine sponge.
Step 3:using the magic eraser gently wipe the part where has the pen stains
Step 4:after cleaning you can use a dry cloth to wipe up the dirts on the walls
Step 5:finally, you just need to put the magic eraser into clean water, the dirty will be dissolve automatically.
En world sales magic eraser sponge En world dedicated cleaning sponge...
Magic Melamine Sponge
Dec 21, 2008 | GE 106591 Coffee Maker
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
The coffee could be hotter
Clean it. Use the manufacturer procedure. If that doesn't work, you can obtain a new thermostatic button. Outlet temp for most coffee makers is 180 F.
Mar 15, 2008 | Mr. Coffee MRCTB Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
136 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
