Question about BenQ Joybook 5000 Notebook
My dvdrw is not recognised by BIOS, therefore, not able to boot from CD. Bios version 1.3.
  • 629 Answers
If the drive is not recognized in the BIOS, either the issue is with the drive or your system board. try to remove and reconnect the drive from the notebook. if this does not work, you can also try a BIOS update, or test if your drive will be detected on another notebook. if the drive works fine on another system and another drive also fails on your system, it would be an issue on the system board. If the drive, however, fails on another system, you'll need to get a drive replacement.
Posted on Sep 06, 2010
Can legacy bios ever boot gpt efi, say with a linux efi emulation.
Ok so when it's trying to boot in legacy mode it will see the hard disk as unformatted. Therefore it won't boot Windows 8 or 10. You need to get the bios back into booting uefi.
Resetting the bios should do that anyway, but there is no reason why you shouldn't be able to get into the bios to make that change. Try doing this with the hard disk unplugged so you don't risk trashing it.
Jul 27, 2016 | Legacy Computers & Internet
I have a NP770Z7E-S01UB notebook. I can't get BIOS changes to stick so that I can boot from a CD.
Hi
BIOS changes are usually saved using the F10 key or going to the EXIT menu and using SAVE & EXIT. This is detailed on page 99 of the User Guide which you can download from here:-
http://downloadcenter.samsung.com/content/UM/201408/20140828134026815/Win8_Manual_eng.pdf
If you use the Esc key to leave the BIOS, your changes will not e saved.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Computers & Internet
Hard drive not being recognised by compaq presario SR1975AN on warm boot
The hard disk may be running too hot.
The desktop case inside temperature maybe too hot. Check the power supply fan/CPU fan are operating correctly. You may need additional cooling in the desktop case an additional fan near the hard disk.
Mar 23, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
Acer 4810t bios upgrade interrupted during the process .how to re flash the bios as I'm not able to boot.Start up screen freezing at F2. please help.
Try getting a bootable disk of dos. May be u can get FREE DOS.
Boot it up and try flashing it in DOS mode if the BIOS has a DOS version available.
Dec 21, 2010 | Acer LA 4810TZ-4870 PM SU4100 4GB...
Bios replacing
You will need to download the BIOS installation software for DOS if they have one from the motherboard manufacturer and the BIOS file. You will then need to make a bootable dos cd-r disc using windows. Once you have done this you can use the disc to start your computer in DOS mode. Then burn the BIOS DOS SOFTWARE and the BIOS FILE on a cd-r. Then you will be able to run the BIOS software from dos and install the bios file. You could also install windows on a USB hard drive then try to boot from it if your computer can boot from USB and the USB boot device option is still working.
Nov 26, 2009 | ASUS A8V-E SE Motherboard
BIOS stops booting with two CD checks
1. Chek whether the time and date is correct
2. If No, change BIOS Battery, if Yes, No need to change the Battery
3. Install the latest Version BIOS (if the existing is the L8st, then reinstall)
4. Selct "Load Optimal Default" in BIOS and try to boot
Dec 15, 2008 | E-Machines eMachines Desktop PC
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
Floppy cd rom or hard drive not recognised in bios
most probably the bios battery is week (that happened to me a few times on some old unused comps. ) ! Keep the computer pluged in for an hour or so ... and hopefully the next time u enter bios and set the booting devices, they will remain set 1
Mar 10, 2008 | Gigabyte GA-6WMM7 Motherboard
BenQ Joybook 5000 Notebook Logo
81 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
