Question about Philips FR965DHT Receiver
Philips digital audio/video surround receiver FR965/17
My receiver turnes off right after i turn it on if im lucy and it stays on i dont get any sound from any speaker can any one help
Same here ,men , i start the tearing apart hehehe, and i think it can be one the little chip located behind the control panel so i remove the white ribbon, the one looking like an ide connector for a hard drive, and guess what it turns on, but when you connect the ribbon just goes back to stand by mode, maybe requires a flash on one of the little chips, same thing happen to a lap top that i use to have, just shorted 2 of the pins and start working normally, im gonna find more info but there sems to be nothing about this amp, high five from mexico men
Posted on Jul 08, 2008
What do i need and how do i connect my iphone to my phillips FR 968 so i can listen to music??
http://www.manualslib.com/manual/128395/Philips-Fr-968.html?page=11#manual
Looks like you need an audio splitter to Left/Right mini plugs.
Such a cable goes from the earphone output on your iPhone to the CD in plugs on the back.
Alternatively you could purchase a bluetooth converter, plug it into your digital input, and pair it with your iPhone.
Mar 22, 2015 | Philips Fr-968 Digital Audio/video...
I think my receiver may have a blown fuse, when plugged in and I try to turn it on the red power light comes on and immediately shuts off, could this be a fuse problem?? If so how can i fix this
If your main power fuse was blown, there would be no power at all. You may be looking at a blown preamp or an overheated component inside your receiver. You may want to take it in to a service technician. Have you tried to contact Philips customer service?
Mar 30, 2014 | Philips"fr 975"receiver"digital...
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
No sound out of surround back speakers
It sounds like you don't have your surround sound source set up properly (your DVD player is not set up for PCM sound).
the best quality audio will be to set up either digital or optical audio between the DVD and the receiver.
Once you have connected the optical or digital audio cable between the DVD and receiver, you have to go into the DVD player audio setup and change it to PCM digital audio or you will not get surround sound. DVD players are not set up by default to output surround sound.
Sep 05, 2008 | Yamaha RX-Z9 Receiver
No surround sound
if the unit has no digital dvd 5,1 input it will not play 5.1 output, unless the unit is switched into a virtual surround mode(theatre/etc) mode try with a new dvd film with a digital glassfiber cabel if it shows 5.1 on the display of the receiver. if it shows 5.1 digital surround than the end stage of your surround is blown and needs to be replaced
pauliesbouth
Aug 25, 2008 | Yamaha HTR-5650 Receiver
Philips FR965/17 Digital Audio/Video Surround Receiver
Well, if the headphones work,then the amp in the rcvr is working.
Make sure speakers are hooked up properly (Spr A, Spr B, etc.)
Be sure speakers are selected properly on the front panel.Look in the owners manual and see if its possible to reset the reciever.If this is an older unit, speaker relay may be dirty or defective or unit is in protection.If unit used to make a click after a few seconds when first turned on and now it doesn't, then the relay is not working.
Jul 21, 2008 | Philips FR965DHT Receiver
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Philips FR965DHT Receiver Logo
473 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
