Question about TC Electronic Finalizer EXpress Compressors Limiter Gates
Hi my tc finalizer (upgradet to fin plus) recently stays switches off. the problem is always after switching on the complete environment. it needs a while that th tc ´s display is lighted. these periods seemed to get longer and longer. today the tc seems to stay dead. any solutions? thanks, walter
  • TC Electronic Master
  • 5,603 Answers
First try the self test function.
If it will not respond I suspect the unit has a power supply problem and will require servicing. This is an internal thing and not DIY unless you have electronic experience.
Posted on Sep 06, 2010
VoiceLive
I had this problem. I sprayed the switches with contact cleaner from outside and jiggled them a bit. I also powered it from a different socket. The problem has not recurred since.
Oct 22, 2017 | TC Electronic TC Helicon VoiceLive Touch...
Kurzweil Sp2x
It may be the line current at those venues.
If you have a lightweight switchmode supply, you can try adding some ferrites to the power cord from the wall. but you almost need to switch to an older style heavy transformer supply for reliablity. It is my guess there is a great deal of noise on the supply current at those vehues you have had problems at. That noise does not play well with switchmode.
Feb 04, 2012 | Kurzweil Music
Hi, I have a tc electronics finalizer 48k and i find that i am getting background hiss on my recordings, i have isolated the problem to the finalizer, is this a psu problem?
A common problem with signal-to-noise ratio is having too much gain in the FINAL stages of an audio path, be it analog gain or gain in a digital path. If signals or data is recorded in early stages at too low a level and then normalized in the final stages to bring up to desired level, the dynamic range of the level is sacrificed and the noise level will be large versus the desired signal.
Jul 19, 2011 | TC Electronic Finalizer EXpress...
Wah wont always bypass when I let off.
The switch has probably failed or the pad that actuates it. These things take a beating. Verify that the switch is mechanically working, and then check with ohmmeter. The pad triggering the switch gets worn and fails to actuate the switch completely is common on pedals. The internal parts of the switches fail... NOTE: many of these switches have metric mounts and are hard to find exact repalcements.
Feb 12, 2011 | Behringer HB01 Hellbabe Wah Pedal
Is it possible to completely cut out earth hum on a guitar in a home environment. Or is a little bit of hum always gonna be present<
The key is to keep the guitar away from magnetic fields. Transformers in amps are a common source. You could use a graphic equalizer to "notch" out the power line frequency. Make sure your amp isn't the source of the hum by unplugging guitar cable. Then make sure the guitar cable is good by plugging it in and shorting the open end. Then plug into the guitar to check.
You may find your cable is sub-standard, or you MAY have to set yourself up to use balanced connections if your guitar has XLR output connector.
Sometimes the grounding of the conductive paint in the electronics well of the guitar gets ungrounded... check that using an ohmmeter.
Nov 16, 2010 | Fender Limited Edition Mustang...
DOES A 2003 NISSAN PATROL HAVE A TIMING BELT OR CHAIN 4CYL 3 LT THANKS
This was posted under musical instruments with" TC Electronic Finalizer Express..." as the header. It belongs under Automotives or Cars. Hope this helps.
Oct 31, 2010 | TC Electronic Finalizer EXpress...
Hi the buttons are sticking on my finalizer express what should I do
If the buttons are MECHANICALLY sticking to the escutcheon they pass through, try using a bit of CRC226 spray on a QTip to wipe the sides of the buttons.
CRC226 is available at Home Depot in the EELECTRICAL dept.
Aug 02, 2010 | TC Electronic Finalizer EXpress...
TC Electronic D-Two Power unit locked up display
I don't know if this will help. Have you looked for a battery on the circuit board that backs up the memory? A lot of synths use them and when they go the unit quits functioning. Some will start right up again once the battery is replaced others require a system update through a download. Anyways I always recommend contacting the company in question. They should be able to tell you simply whether it needs servicing or not:http://tcsupport.custhelp.com/cgi-bin/tcsupport.cfg/php/enduser/ask.php
Jul 14, 2010 | TC Electronic Finalizer EXpress...
C above middle C won't play
If the key itself is hard to move, you need to find out why. Is the momentary contact switch under the key non-functional?
The Momentary Contact Switch is a lot like that used on a computer keyboard, or a computer mouse.
A metal, or plastic case that surrounds an upside down T shaped plastic piece, which pushes down on a thin spring metal 'diaphragm'. The 'diaphragm' is convex shaped, and the curvature goes up.
In the center at the bottom of this switch, is a contact. The metal diaphragm connects to one side of the circuit, and the contact at the bottom connects to the other side of the circuit.
As the metal diaphragm is flattened, and touches the center contact, the circuit is complete.
The convex shaped metal diaphragm then curves back up, (Because it is spring metal), and breaks the circuit, as your finger comes off of the key.
This makes it a Momentary Contact switch.
When the circuit is complete, electricity goes to electronic components, that make That particular sound. (Note)
Perhaps, parts inside that momentary contact switch are broken. They moved at first allowing you to use this switch, but with extra force. Finally the switch broke completely, and is non-functional now.
If the sound itself is diminishing, it is a Capacitor which is the problem. (Electronic keyboard) Just thought I would add this.
From my own knowledge bank.
Aug 23, 2009 | Yamaha Full-Size Keyboard
No sound, seemingly preamp?
Hi there. Scratching, popping etc. is a semiconductor (transistor or IC) junction going bad. Must be replaced. With the amp on, try tapping all around the board/s with a plastic screwdriver handle to see if it is a mechanical problem instead.
Thanks
Paul
Jun 09, 2009 | Music
TC Electronic Finalizer EXpress Compressors Limiter Gates Logo
272 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
Tom Chichester
Seanzilla
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
