Question about Refrigerators
RE221S-R westinghouse fridge wont stop running,builds oce block in fridge area
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Tip
How to stop water dripping from front of fridge
If you have a fridge with water running out the front (bottom area) of the door it is usually a blocked water runaway duct eg the cyclic defrost fridge defrost,s every time it turns off.The water comes from the plate that gets cold in the fridge compartment and when it defrosts the water drip,s into avally which inturn runs away usually through a hole in the back wall and down to the compressor area to be evaporated away, if the hole blocks up the water will run over the top.To clean the hole a cable tie is usually a good solution,just put it in the hole and toggle it back and forth until the water runs away.Another way would be to attach a vacume cleaner to the pipe near the compressor area and **** the blockage through,This will also work for frost free models.Hope This Helps Kind Regards.
on Dec 08, 2009 | Refrigerators
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
I have got westinghouse fridge. The freezer is working but the fridge does not get cold at all
Is there any sign at all of snow/ice build-up in the freezer section ??
Is the fan in the freezer running ??
Need more info..
Dec 24, 2010 | Westinghouse Refrigerators
Fridge compartment of westinghouse bj433v-r is not refrigerating, freezer is refrigerating. The fridge fan is working.
The freezer control on most units is just a door that you open or close to let more or less air into refirig from freezer. The higher the setting, the less air to the frig side.
If frost build-up on freezer side, then you have a defrost problem. Too much frost build-up on evaporator is blocking air flow to refrig.
Nov 05, 2009 | Dryers
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
We have a Westinghouse WSE6100SA - side by side fridge freezer. Still under warranty. The repair guys have been twice now to temp fix the freezer, to no avail. the freezer is not freezing or I should say...
sound like the air supply baffel is the problem / or if the lower air vent is freezing over then the water is building due to icemaker / the water overflows on the inlet water fill tube to the icemaker and running down the inside behind the panel / they can take the fill tube from a ge icemaker kit and cut it in half and slide over the tube thats in your frig and it will keep it from running over / a problem wgi has had for awhile now / if you havent call sears i would since they should know the same.
Nov 25, 2008 | Refrigerators
Westinghouse Fridge problem
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
