Question about Garden
What is the correct sharpening angle for this saw
  • acmelin Sep 06, 2010
    It's a Talon 14" electric chainsaw - AC211114A - I have an electric sharpener, the chain sits on a turntable that is to be turned and then locked at the correct sharpening angle: but what is the angle? I can't find a Talon web site with the info.
    Thanks
  • acmelin Sep 07, 2010
    Talon 14" electric chainsaw - AC211114A - I tried that but it seems to vary, I'd just like to get it correct: so you don't know what the angle is supposed to be then? or where I can find out?
  • 109 Answers
SOURCE: need sharpening angles
The angle is 30 degrees.
Posted on May 03, 2009
VtToolMan
  • 704 Answers
SOURCE: i need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
rwvanlue
  • 486 Answers
SOURCE: where will i get a manual for a pro performance
30 or 35 degrees to sharpen cutter.
Posted on Nov 11, 2009
Testimonial: "thanks guru chainsaw is know sharpened thank you very much did not exspect an answer so quickly many thanks"
miket756
  • 2702 Answers
SOURCE: why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Posted on Mar 28, 2010
nedkelly900
  • 345 Answers
SOURCE: which angle to sharpen Poulan chainsaw #2375 18
30 degrees
Posted on Apr 28, 2010
What angle to sharpen a Lenox Chain Saw?
Typical sharpening angle is 30 to 35 degrees.
There is a handy little file holder available with these degrees marked on it. If you can get one, you should be able to determine what angle was on your chain to begin with.
My personal preference is 35 degrees.
Jun 18, 2015 | Garden
Chain saw sharpening angle
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Apr 22, 2015 | Poulan 16" 38cc Gas Chain Saw P3816
What is sharpening angle for Poulan chain 952051209?
Unless it has been changed from the factory set up it is 3/8 Low Profile and takes a 5/32 file.
Remember you can go too small with the file and get away with it as long as you know what you are doing. Too big means you cannot achieve the correct profile.
You can always take your chain in to be sharpened. In my area, I have taken 2 chains to be sharpened recently and, it only cost be $10 bucks.
Good luck with your saw.
Sep 07, 2014 | Poulan Garden
What is oregon chain sharpen angle
I sharpen to 35 degrees, right or wrong. I'm sure there are more aggressive angles for the larger pro-saws, but this has served me well over the years on many brands of chain.
Jun 12, 2014 | Poulan Pro Chain Saw 46cc 20"
How to sharpen chain saw chain
Hi
You need to purchase the correct diameter file for the size of chain you have fitted on your saw. Suggest also that you buy a Stilh file holder (this is a frame which holds the file, and acts as a guide to give you correct filing angle and depth, just a few dollars).
Do not file too much off each time, I give each tooth two files strokes only. You have to keep the saw sharp all the time, I sharpen every two tank fills of fuel.
Suggest you Google the subject, Oregon chain is a good make and will have details of how to sharpen
Good luck
Jacko from down under
May 15, 2014 | Computers & Internet
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Apr 18, 2011 | Husqvarna Garden
Saw cut is not straight. It curves until the chain freezes. Model 330 type #1 Chain saw.
This problem is caused by sharpening the chain on one side more than the other or can be caused by having the angle wrong when sharpening one side which causes one side to cut better than the other. The only solution is to get it sharpened professionally. All chainsaw users have to do this every few times we sharpen them.
Sep 06, 2010 | Sport & Outdoor - Others
What is the chain saw blade angle?
This is the angle that you cut each tooth. if you have a chain sharpener you will see numbers on it with a line directly below it. A good standard is 25 degrees, if you want it for ripping purposes you can modify the angle.
moz-screenshot-2.pngmoz-screenshot-3.pngYou really want to match the angle that the blade or chain as been set for.
I would also recommend this website. http://www.wikihow.com/Sharpen-a-Chainsaw
good luck
Apr 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cuts at an angle
The sharpening of the chain is most probably not to the correct angles and not even in relation to the other teeth.
You need to sharpen the chain so all the teeth are to the same length and angle (sometimes there is a small black mark on each tooth to show you the angle and how far you can sharpen back to) . Mark where the smallest tooth is and the bring the others to the same length. Also check the rakers are at the correct height in relation to the teeth that you have just sharpened (use a depth gauge to help)
It is quite unlikely that the bar is bent but taking it off and laying it on a flat surface should tell you if it is. Check the bar for burrs and file them down if there is any.
If you are not sure about any of this then take it to a chainsaw shop and get them to sharpen the chain and check the bar for you.
Hope this helps
Mar 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know the right angle to sharpen my chainsaw
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
