Question about Microwave Ovens
Sharp r 21atp microwave everything working but not heating up anything
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: sharp r 21atp microwave everything working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 13, 2010
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
heatman101
Oct 13, 2010 | Microwave Ovens
Everything works except it won't heat anything. can you tell me what is wrong. it is a sharp microwave, model # r-306 lk, serial # 85407. thank you.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
hdshj
Apr 21, 2010 | Maytag MMC5000 Microwave Oven
Sharp modelR1381 everything works but will notheat
If it runs and makes normal noise but just no heat, issues is either a loose connector to magnetron or at diode to capacitor. Be careful with capacitor because it stores thousands of volts.
Nov 21, 2009 | Sharp Microwave Ovens
Everything seems to be working but it doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 11, 2009 | Sharp R-530ES Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Not heating up anything
Not knowing how much run time you have on the microwave , makes it hard to diagnose the problem but If everything appears to be working properly (as you describe) then you may have a bad/damaged or disconnected magnetron tube inside it. That kind of service should be done by professionals. Exposure to Microwave energy is not something you should mess around with unless you know what you are doing.. Good Luck
Aug 13, 2008 | Sharp R-820B Convection/Microwave Oven
Need inner door surround for a sharp 1000w R-21ATP Microwave
Start at the link below. Eventualy you will be led to a reliable source to purchase parts.
After the surround is replaced, it is important that the microwave oven is properly tested for radiation leaks. This is a serious specification. I think they will strongly tell you to send the oven in for proper service and testing rather than fix it yourself.
http://www.sharpusa.com/products/support/0,2309,,00.html
Jerry G.
May 02, 2008 | Microwave Ovens
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
