Question about TallyGenicom 8008 Laser Printer
Printer Password I've bought this printer used, but when I log into the printer's HTML interface I can't perform maintenance or change network settings or upgrade firmware, as it's passworded. The passwords are not the default ones listed in the manual like I was told they were. can I reset the password or get around it?
  • Anonymous May 28, 2008
    Exact same problem, how do you reset to the default?
  • tuck_1981 Jul 10, 2008
    I've found out that the default passwords in the manual and on genicom homepage are listed as 'super' and 'adm'. The password default is ACTUALLY "sysadm".
    Novelist:
  • 169 Answers
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
Posted on Nov 13, 2008
Most of the printers connected in network can be accessed through a web page. Is it possible to perform calibration operations on Printronix T5204R printer from an inbuilt html page in the printer?
Most calibrations have to be performed onsite by logging in as the CSE (Customer Service Engineer) or the Administrator. There are several simple calibrations that can be performed by a user but most need you to log in.
Apr 04, 2016 | Printronix Office Equipment & Supplies
I want to find out how to secure my network. My neighhbours ar loggin in on because I pay for high speed access. The router is Belkin g Plus MIMO 180170
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Jun 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Purchased a new wireless HP 6500A inkjet printer and am unable to connect to my wireless network.
Wireless printers can be a bit tricky to setup as they all have different interfaces to work with. The thing to keep in mind is that the printer has to be set up to access your networks router just as if it were a computer, so you will have to use the often awkward interface on the device to enter the settings for your network. If you are on an unsecured network (one that does not require a password) it may be as simple as using the menu on the printer to find the network setup and telling it to search for networks and choose your networks name from the list. However if you have a password on your network you will have to also enter the security type and the encryption type. This may require some trial and error if you're not familiar with the exact type of security and encryption your router uses, once you chose both of these, you will be asked for your password also known as the network key. This is the same password required for any other device you use on your network. If you cant seem to figure it out, you can log into your router and check the exact settings there and compare them to what the printer is asking you for.
Give that a try, if you are still having problems get back to me and I can try to walk you through it further.
Hope this was helpful
May 31, 2011 | NetGear RangeMax WPN824 Router
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Restraunt Pro Express problems
Option 1 (Ethernet II only): Using a web browser, type the default IP address (found on a label on the interface card) into the address field of your web browser. The configuration screen should appear. The default password for the interface is Epson. We highly recommend this be changed. Once the web interface is running, all application, network, printer and password settings can be modified.
from: http://www.beaglehardware.com/howtoethernet.html
Jun 24, 2009 | Pc America Restaurant Pro Express
Windows 98 OS compatibility with XP printer
Get a converter or USB 2.0 power adapter. or else use your printer on network sharing.. thats would be the best way,.
Feb 04, 2009 | Microsoft Windows 98 for PC
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
TallyGenicom 8008 Laser Printer Logo
2,682 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
