Question about RCA TruFlat 27F520T 27" TV
Hi My name is Mei and my true-flat RCA television is acting really funny. I'm not sure what is really wrong with it except the first half of my tv is flipped upside down within the screen. So it looks like only half the tv works because that is the case only half the tv work and the other half doesn't. What do u suggest i do to try to fix it?
  • 11 Answers
SOURCE: RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Posted on Jan 08, 2008
SOURCE: 13 inch rca true flat tv
yeah..same problems with my RCA T.V...when i turn it on, after 1 minutes or even shorter, it turn off by itself, then it will turn on by itself....just repeat the same thing again and again until i unplug it....anyone can help..please!!! thx
Posted on Feb 24, 2008
jerryg50
  • 1689 Answers
SOURCE: RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
bhur
  • 85 Answers
SOURCE: RCA tv.speakers internal
buy another speaker of your tv for replacement
Posted on Jun 03, 2008
honeymokey
  • 3113 Answers
SOURCE: My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
Posted on Jan 28, 2011
Half the screen to my flat screen tv is Pink! Whats wrong?
T'Con board fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 18, 2014 | Televison & Video
Is RCA TruFlat TV HD?
if the tv has a hdmi port its hd
Oct 06, 2014 | RCA 24" True Flat Color TV w/rmt
42 in plasma RCA tv won't power on just makes a clicking noise after trying it a couple of times the clicking sound stopped and still nothing happens took it to a repair person he said it was 2 boards that...
its possible that the repair man lied if it is an rca then call the company and have them send you replacements. of course this will require money but less than a new tv
Sep 04, 2013 | Zenith Z50PX2D 50 in. Plasma HDTV
I have an L32HD31 TV and just recently the screen started to display these fine horizontal lines that cover 3/4 of the bottom half of the screen. Was wondering if there was a fix for this and what could be...
Check all your input cables. If RF coax, make sure they are just beyond hand tight. If RCA, twist each a few times to burnish (clean) connections. This is especially true if you are doing Component viodeo (Red, Green & Blue).
Nov 25, 2010 | RCA L32HD31 32 in. LCD HDTV
Around edge of tv the colors blue/red/green/blurry...
my 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do anything..how much will it cost to fix this problem?kodigaston@hotmail.com
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 61 inch not working properly
The vertical heigth is too high. whats the model number of your set?
Jun 12, 2008 | RCA D61W20 61" Rear Projection Television
Tv wont come on
Good Day,
If you use your TV a lot then you need to replace the lamp, but if you only use your TV about 8 hour a day, then you also may need to replace the ballast.
The lamp is really easy to change. You should get at least 5,000 hours on your lamp.
Call RCA customer service and ask for a concession to replace the lamp and ballast. This is a common problem for RCA!
Good luck, God Bless.
Jun 11, 2008 | RCA Televison & Video
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
Apr 03, 2008 | RCA Scenium PHD50300 50 in. Plasma...
TV wont come on.
do the lights blink at all or do they just come on? you might need to replace the ballast - this is what provides the high voltage to the bulb (lamp)
Feb 18, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Top inch and a half of tv picture cut off.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Oct 16, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
RCA TruFlat  27F520T 27" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
