Question about HP Computers & Internet
My laptop does not start sometimes when i click on button ?
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 20, 2010
My laptop sometimes does not have a display,sometimes display is distorted?
Laptops usualy have a button to export your display. You can click it by holding in the "fn" button that's located left from the windows button(usualy). When holding it you should look for a button with 2 squares (like a tv) thats normaly the F10 button. If you click it your screen goes black or comes back. Also check your driver, check if its updated(what windows do you have?)
When does the screen disappear? Is it when you start a program or just now and then? You can run programs or games in xp mode or you can adjust their screen settings because they might not be compatible with your driver/version of windows/...
Jun 13, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Ihave an acer laptop,,,.,., i was installed w7 on my laptop,,that time my laptop work slowly,,, and also the black spots on monitor screen,,
See whether you laptop have the minimum system requirment to install Windows7, windows 7 needs more graphics support than others os.
May 09, 2011 | Computers & Internet
Slow acer logo loading
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Apr 19, 2011 | Acer Aspire 4315 Notebook
I have a laptop and it runs so slow. The battery life is beyond horrible so I have to keep it plugged up at all times. I have not used this laptop alot until now because I am a college student. Its almost...
2. Select Manage.
Mar 21, 2011 | Everex StepNote NC1500 Notebook
My laptop is sort of running slower and I wondered if it was because my space is almost full on my laptop? And I also wanted to know if I can do anything to make it go back to normal. One other thing is...
First of all, simply delete your browsing history and cookies. Websites will sometimes download cookies or copies of their pages to your hard drive for faster loading later. The unfortunate thing is that this can slow down your pc. Using your browser, delete your browsing history, cookies, and all offline content.
If your computer takes a long time to boot up, take note of how many programs you have loading on start up. Pay attention to the bottom right of your screen and watch the icons. Having a large amount of programs loading on start up will make your boot times considerably slower. Open these programs and tell them not to start on start-up, or simply delete them if you don't use them.
Sometimes spyware or other malware will be downloaded to your computer and can adversly affect performance. I suggest downloading a spyware deleting program like Lavasoft's AdAware. It is free and reliable. When you use it, make sure that you update the definitions each time to make sure you search for the newest spyware. Try running the tests at least once a week.
Mar 15, 2011 | Computers & Internet
Hallo my aspireone 532h-2ds working slowly i already reinstall window but its stil slow
2. Select Manage.
Jan 19, 2011 | Acer Aspire One PC Notebook
Acer travelmate 4150 very slow
2. Select Manage.
Jan 13, 2011 | Acer TravelMate 2300 Notebook
LAPTOP SLOW
2. Select Manage.
Nov 06, 2010 | Acer Aspire 4720 Notebook
Why the laptop are slow
There are any number of thing that can slow down a computer or laptop. Please click on this link and follow my instructions to speed up your computer or laptop :-
http://www.fixya.com/support/r5946321-fixing_slow_laptop_desktop_computer
Nov 01, 2010 | HP Pavilion dv6000z Notebook
SOMETIMES IF I SHOTDOWN MY LAPTOP INSP'N 1545 THEY HANG AND SOMETIMES IF I ON THEY ALSO VERY SLOW TO OPEN...WHAT CAN I DO...
System hangs and not shutting down or slow may be due to Virus or worm infection.Scan your PC with a good antivirus like Kaspersky Internet security 2010 or A-Squared Anti-Malware.Both can detect malware too.Make sure you update the program with the lastest updates.
Kaspersky Internet Security 2010 can be download from here
http://downloads.kaspersky-labs.com/trial/registered/3NKDGRXIM7FJ5ZTSIAFW/kis9.0.0.736en.exe
A-squared Anti-malware :
http://download.cnet.com/A-Squared-Anti-Malware/3000-2239_4-10292236.html?part=dl-6251182&subj=dl&tag=button
and click start button;select "Run", type "msconfig", Press enter key.
Click "Startup" tab and untick all the programs that are running during start up except Antivirus program.
Dec 24, 2009 | Dell Computers & Internet
Computers & Internet Logo
397 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
