Question about Refrigerators
The refridrator part is freezing all the food is froze but the freezer is ok
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
You didn't post your model number or brand but the typical cause of this problem is a stuck damper door between the freezer and refrigerator.
Post details on your model and I'll try to point you to some online information.
James
Posted on Sep 06, 2010
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Lfx25971 will not dispense water
My water dispensor INSIDE the door froze up.... GE
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Jun 08, 2012 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
What is power cool
This is a program when the freezer is meant to cool off in a hurry such as jet cool or a freeze it.
When the freezer is loaded with a fresh batch of food to be frozed in a hurry you can select this program .The freezer will run to cool at the highest so that the food is frozen faster.
Sep 18, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Please help my side by side ge refridreator is
It sounds like the main control board is bad , IF , there is no frost on the inside rear freezer wall . The old board ( yours ) is under a factory recall . I would suggest calling GE factory service , to have this replaced under warrenty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new board part number is WR55X10656 .
If there is a frost build up , then that would be a defrost problem , with a different solution . Please reply back , if that is the case .
Nov 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a LG bottom freezer refrigerator we bought in 12/08 and the ice maker is not making ice but still sounds like it is and the water line is open. Freezer is freezing foods ok and the top of...
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
May 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
