Question about FrancisFrancis! X1 Espresso Machine
Hi, I have an X1 francis espresso machine. I am having a problem with the machine heating up the water. I am not sure if it is the element, or the thermostat. The temperature guage does not rise above 20* C, however it feels much hotter than that. My question is, where is the thermostat located? Is the thermostat part of the temperature guage? I am not sure if I should replace the element, thermostat, or both. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
The thermostat is a bit that goes into a hole on the boiler, connected by a wire to the gauge. It is most likely that the thermostat has come unstuck from the boiler and is registering incorrectly.
Posted on Jan 23, 2015
SOURCE: Francis francis x1, blocked steamer
I had the same problem on an X5 model, eventually we realized that you we could unscrew the entire nozzel fairly easily (not just the little steam attachment on the end). Once we'd done this, it was easy to soak the entire nozzel in hot soapy water.  I then used a needle and dental floss to get the entire thing clean inside.  Not very technical, but it worked for me.  Worth a try if you haven't already sorted this.
Posted on Mar 17, 2009
  • 10 Answers
SOURCE: francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
  • 1089 Answers
SOURCE: my francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Posted on Jul 16, 2009
SOURCE: I bought a second hand Francis Francis X1 Espresso
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Posted on Feb 09, 2010
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
X2 francis francis trips breaker when plugged in?
Hi
Tripping the breaker is usually a bad heating element. You have to check each heating element to determine which element is bad (2 on and X2). Use an ohms meter and check the 2 elements on each boiler for a reading of between 12 and 16 ohms. If no reading that is the bad element. Its in an aluminum boiler so lubricate the end of the bolts(threads) before you try to remove them or they might break.
Apr 27, 2011 | FrancisFrancis! X1 - Stainless Steel...
My Francis Francis coffee machine shorts out and fuses all the lights in my house. How can I fix this
Hi
I would say that it is probably your heating element. You need to install a GFI in your outlet to prevent an electrical shock, and that will prevent the machine from taking out the whole house, but it will take out anything that is on the same circuit.
Nov 14, 2010 | FrancisFrancis! X1 - Stainless Steel...
When I turn on my Francis Francis it blows the
Hi
you have a blown element and is grounding the machine through the boiler.
Apr 02, 2010 | FrancisFrancis! X1 - Stainless Steel...
I bought a second hand Francis Francis X1 Espresso Coffee Machine & the gauge & Milk frother are no longer working. Any advice?
Feb 02, 2010 | FrancisFrancis! X1 - Stainless Steel...
I have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Oct 12, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
138 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
