Question about Garmin Rino 530 GPS Receiver
My Rhino 530 wont turn on - Garmin Rino 530 GPS Receiver
3 Suggested Answers
SOURCE: rhino 530 no signal
I have a 530 which was intermittently receiving sat signals for about a day then it quit. I disassembled it and found that the circuit trace that connects to the GPS antenna had cracked at the edge of the solder connection. I added a short jumper on the trace and that fixed the problem. Note: very fine soldering. Not for the novis.
Posted on Nov 12, 2008
SOURCE: Power Switch will not turn my Rhino 530 HCx on
When I try to turn it on it comes up with the “rino” initialization screen and buzzes/vibrates at 5 second intervals. It never goes past this screen. Occasionally, for about 1 second a small white bar will appear across the bottom saying “0%. I’ve recharged the Li battery and got the same result. I’ve tried it while connected to the charger. Same result. I’ve tried using the optional 4 AA battery pack with fresh alkaline batteries. Same result. Did the factory reboot (page/enter/power buttons). Same – except instead of a buzz/vibrate I get the tone every 5 seconds. Have to remove battery to turn off.
Contacted Garmin tech support today (10/22) - hope to hear from them soon.
Posted on Oct 22, 2009
I have a 2009 Yamaha rhino 700 cutting out at half throttle and popping cuts out at 35 mph
Cutting out at 32mph - Yamaha Rhino Forum - Rhino Forums.net
www.rhinoforums.net > ... > Members > Forum Help, Questions and Info
Apr 23, 2011 - 12 posts - ‎8 authors Once it cuts out I let off the gas to let the speed drop a little, it pulls fine then ... The reason I say that is because feathering the throttle gets you 4 mph more .... Spent halfa night starting it and reving it trying to go somewhere but I'd give it ... Join Date: Sep2009 ... 2008 yamaha rhino 700 cuts out at 40 mph. 700 Sputtering with constant throttle
Jul 18, 2012
Rhino missing/dying/backfiring when running on top ...
Aug 12, 2011
2009 Rhino 700 Crank No Start
Dec 12, 2010
full throttle
Aug 31, 2009
More results from www.rhinoforums.net
Sep 27, 2015 | Yamaha Motorcycles
I have a Yamaha Rhino 660 that has sitting for about a year. I have replaced the spark plug, but it still will not start, any suggestions?
I am assuming that your Rhino turns over when trying to start it. Check for gas, shutoff valve in the run position, gas cap vent working, do you have spark? If you have old gas try draining all the gas from your tank. Gas that sits too long goes stale and has a tendency to gum everything up.
Aug 22, 2010 | Yamaha XT 660 R Motorcycles
Sep 09, 2009 | Garmin Rino 530 GPS Receiver
My gps won't work
Same solution like here : http://www.fixya.com/support/t906770-no_map_displayed
Dec 02, 2008 | Navman iCN 530 GPS Receiver
Rhino 530 no signal
Sep 30, 2008 | Garmin Rino 530 GPS Receiver
Garmin 530 gps radio
I am guessing that the unit is out of warranty. if this is the case go to http://www8.garmin.com/support/outofwarranty.html to handle your repairs. while I have not personally sent anything to Garmin, I don't expect you to have any problems. Garmin is a highly recognized company for both thier products and for there service.
Pat
Aug 12, 2008 | Garmin Rino 120 2-Way Radio
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 05, 2008 | Garmin Rino 120 2-Way Radio
X-530
Have you switched off your built-in speakers? Go to control panel, click on sound, turn off your built-ins if they are on, and select the configuraion of your speakers--that might do it. If not, check device manager to see if any checks are present, which will identify where the problem is.
Apr 06, 2008 | Logitech X-530 Computer Speakers
Garmin Rino 530 GPS Receiver Logo
47 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
