Hi
Thanks for using FixYa. Yes you
are absolutely right the issue is with the Thermal Fuse going bad and needs to
be replaced. It is mounted to the exhaust
duct inside the back cover panel. Also, often a dryer heating element
burns out, but doesn't trip the circuit breaker or blow a fuse. The heating
element is simply a long coil of special wire. You can check it for continuity
with an ohm meter. No continuity means the element is bad and you need to
replace it. Please do accept the solution
if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hello, I can likely help, I just need to know the make of dryer and the model number. The model is usually on the cabinet behind the door opening. I'll watch for your reply. Macmarkus :)
Sorry I forgot what should have been obvious
BOSCH WTA 4400FF 01
The dryer did function nearly all the afternoon.
At one point the mains disrupt. I plug the dryer in another wall plug. The dryer power on (power light on and internal light on) when I tried to start it up (empty) it powered off.
Now it doesn't power on at all.
Thank U
