Question about Amcor Heating & Cooling
Amcoraire aos 121hx fan come on but compressor does not getting a p8 error code?
  • 3,083 Answers
I read in a blog that the p8 code is low on freon or a conversion valve failure. If the compressor isn't coming on, that would very the error codes.
Unfortunately, it looks like Amcor is out of business, as this excerpt from Amcorairconditioner.com:
Amcor USA is out of business. Their units are being serviced by American Comfort Worldwide, for a fee, 1-877-645-0299.
I read horrible reviews of this unit here:
http://amcorairconditioner.com/
This unit might not be worth getting fixed, from the sounds of things.
Posted on Sep 06, 2010
AmcorAire Duo. Compressor runs, but fan will not. system shuts off after a rew minutes (overheating coils?). Has the fan burned out or is there a relay that needs to be re-set?
There is a solid state fan capacitor for your system, I would change that part first.
We stock a complete line of parts for Amcor Mini Split Systems.
Support@Pridiom.com
201-266-8234 option 2
Sep 07, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Split AC system not cooling.
P-7 Error Code means: DC Voltage Problem in the outdoor unit.
Bad PFC & IPM Circuit Boards.
The Pridiom Group
201-266-8234
Jul 26, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Hi I have an Amcoraire aos121hx mini split, it worked great last summer and this past winter. Haven't used it for a few months and now when I try to get cold or heat it gives a P8 error?
Check the gas pressure by depressing the Schroeder valve under the cap where the gas pipes enter the outdoor unit. you have probably lost some or all of your gas
Apr 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
74 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
