Question about Dell E198WFP LCD Monitor
I have E 198WFP LCD screen with my dell vostro 200. for last few days the screen is very dull. i have adjusted the brightness n contrast to full but couldnt make it right.
  • 1153 Answers
SOURCE: Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Posted on Sep 14, 2007
SOURCE: E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Posted on Dec 13, 2007
  • 238 Answers
SOURCE: brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Posted on Dec 15, 2007
VooDooNOFX
  • 95 Answers
SOURCE: Dell 991 monitor
On the front of the monitor is a menu button. Press it, and using the left and right buttons on the monitor navigate through the menus until you see brightness, contrast, etc. Then adjust them as necessary.
Steven
Posted on Sep 17, 2008
SOURCE: Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Posted on Oct 07, 2008
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
My screen is so dim on my dell vostro 1500. my kids play educational games on it and i'm worried it's so bad for their eyes. the fn key does not work. please help!m thank you.
You can try to go to the power settings and adjust to brightness of your portable system. There should be a battery icon on the lower right portion of your computer, double click it and you should have the power setting. On the bottom portion, there should be a lever where you can set the brightness higher. if this does not work try to adjust contrast in the nVidia Control Panel (assuming you have an nVidia card).
In Vista, go to
Display Settings->Advanced Settings
Click the GeForce tab
Click "Start the NVIDIA Control Panel"
Click the "Display" category
Click "Adjust desktop color settings"
Jul 13, 2011 | Dell Vostro 1500 Notebook
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Bright ness problem for my laptop dell vostro 1500
It should be in your settings for the Digital Vibrance.
Try this:
Right click the desktop, left click "personalize" > display settings > Advanced Settings > GeForce 8xxxM GT, >Start the NVIDIA Control Panel, >Adjust desktop color settings> Digital Vibrance. Move it up to your desired level + 10% or so. I hope that helps you out and have a great weekend.
Jun 14, 2009 | Dell Vostro 1500 Notebook
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
May 13, 2009 | Gateway Profile 5 PC Desktop
Cannot set the brightness, contrast. Locked menu. Dell LCD.
Niceeeee! this really fixed the issue after 15 seconds with the menu button preessed down the lock became unlocked. MAGIC!
Mar 17, 2009 | Dell Dimension 8300 PC Desktop
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Dell E198WFP  LCD Monitor Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
