Question about Kodak EasyShare DX6340 Zoom Digital Camera
Battery won't charge on printer dock any more?
I have an easyshare 6000 printer dock I charge my DX6340 on. The charge light on the printer dock no longer comes on and the battery won't charge. It used to show one bar on the charge indicator for a low-charge battery and would charge till it showed 3 bars. It's not the battery or the printer dock - I also have a CX 7300 camera that I can put the battery in and place it on the printer dock and the battery will charge as normal. That's how I've been charging my batteries lately. Any idea what's wrong with my beloved DX6340 and can I fix it? Otherwise the camera operates normaly.
  • shankster Jun 17, 2008
    KSchwarz20, thank you! - I was about to go shopping for a new camera and a little piece of paper fixed it. Wonderful!
  • Anonymous Feb 15, 2009
    my kodak batteries died i got some rechargeable ones and now the light on the dock wont light up nor does it charge ??
I have a similar model Kodak camera. The paper trick did not work but the problem was the same.
I put a piece of tape over the plastic bump on one side of the battery. That pushed the switch in and the battery charges now.
CX7300
Posted on Aug 09, 2008
    Problem Solver:
  • 12 Answers
I had a similar problem. If you look in the battery compatment you will see a small switch in the keyway that gets pressed down by the key (the plastic rectagualr bump out) on the side of the battery, if the battery is loose the switch does not get pushed down and the dock does not recognize the battery as a Kodak Batery that it should charge. I solved the prblem by taping a singe piece of paper on the opposite side of the battery so that when it slides into the slot it pushes the switch down, I've nver had a problem since.
Posted on May 19, 2008
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
Easyshare dock 6000, won't pick up paper and if hand fed, still messes up!?
Maybe your rollers inside the printer that feed the paper in, are not functioning the way they should. This could just simple to fix, or could mean you having to purchase a new printer.
Not sure how you would fix this.
Hope this helps!
Feb 05, 2010 | Kodak EASYSHARE Printer Dock 6000 Thermal...
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
Need driver for kodak easy share printer ddock 6000 for vista 64 bit system
Click here, its a link to kodak's easyshare printer dock 6000 exactly at the driver download.
Nov 01, 2009 | Kodak EASYSHARE Printer Dock 6000 Thermal...
I have a Kodak EasyShare Camera - DX6340. I'm
Try and use a card reader.
If your cable is faulty it will be dif. to find another since KODAK no longer produce this particular cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
All of a sudden the camera will no longer charge on my Kodak Easy Share dock although the battery is fairly new
ammumama that was the dumbest thing to post. We're trying t o find the problem, not a new camera.
Oct 05, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
DX6340 will not power up!
New batteriy and charge the battery
Make sure the contacts are clean
Jul 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Battery Charging
You HAVE to have the ORIGINAL or KODAK MANUFACTURED battery pack ! If you use any other batteries rechargeable or not. They WILL NOT CHARGE!
Good Luck !
Feb 24, 2009 | Kodak EasyShare Thermal Photo Printer
DX6340 WILL ONLY POWER UP WHEN ATTACHED TO THE EASY SHARE PRINTER DOCK
It's the fuse in the battery circuit - happens frequently but Kodak won't acknowledge a problem with the model. Repair costs aren't worth it vs replacement - and Kodak won't repair if not under warranty
Jan 06, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Kodak EasyShare DX6340 Zoom Digital Camera Logo
590 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
