Question about Samsung SMH7178STD Microwave Oven
Samsung Microwave -SE- Error
Sorry to bother you.
I was just wondering what ever happened with your microwave from this thread:
http://www.fixya.com/support/t244852-samsung_over_range_microwave
Ours is still having the same error.
handle broke off and the Samsung company has no replacement part - NONE. There is not even a factory making it at this time and none in storage.I have been waiting since March 29,2008,heard from them 3 times,but no solution or microwave.
  • Lynne12 May 27, 2008
    IT IS FIXED was REPLACED! I quit trying to get action from the online service dept,and just wrote a letter to Samsung in general with the complaint. 2 days later,a man called from the customer satisfaction dept. and said he would get it done,and a day after that,a service tech called in the AM and came out and replaced it that very afternoon.I was amazed.I Guess it really does depend on who you tell.
    I am quite pleased with this result.
    lynne12
  • Samsung Master
  • 9,086 Answers
Is this where you checked for parts?
http://www.samsungparts.com/search/search.asp
Posted on May 27, 2008
  • William Miller
    William Miller May 27, 2008
    Congrats!
    Did they replace the controller board or the whole oven?
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
Jan 16, 2016 | Samsung Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
My Samsung microwave SMH9187W is getting a 5E or SE error code when I plug it in. Unplugging and replugging use to clear it for a bit but now it happens as soon as I plug it in. I am just out of warranty...
Maybe Just Lucky; I removed the front cover above the door by removing the two screws on top of micro. Then I removed the screw above the controll panel and carefully lifted off the panel. I checked all wire connections while plugged in and the SE code changed to 0. I reset the clock and put the panels back on.
Done Loose Wire
Jun 29, 2011 | Samsung SMH7178STD Microwave Oven
how can i fix se error a samsung microwaveSMH9187ST
Mar 30, 2008 | Samsung SMH7178STD Microwave Oven
Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
450 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
