Question about Emerson SpongeBob SquarePants TV
Lost remote instructions
I lost the instructions for my SpongeBob TV. I am trying to program the channels. Do you know where I can get a copy of the instructions??
Go to emersonradio.com. Select Owners Manuals, at the bottom of the list will be SpongeBob. Click on this and it will bring you to a list of model #'s. Select yours.
Posted on Jun 07, 2008
Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
Oct 10, 2009 | Emerson SpongeBob SquarePants TV
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Lost Instruction sheet for cl034
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
May 12, 2008 | Philips Magnavox Learning Universal Remote
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
Av mode?
well if you change the channel to the highest it goes some TV can be changed to a/v mode
or the lowerest number under 2 sometime a/v might be there
remote stop working due to batteries or drop remote, might have to be replaced either abtteries or whole remote.
Mar 03, 2008 | Emerson SpongeBob SquarePants TV
Remote control lost programing
this is embedded in the control chip of the remote and is rom..best to replace remote i personnaly have lots of luck repairing usually find cracked solder joints..remotes witstand lots of abuse but do break! john
Nov 07, 2006 | Akai PT4298HD Rear Projection Television
Emerson SpongeBob SquarePants TV Logo
269 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
